Seems the sketch only compiles if a use INT.
If I blynk.virtualwrite a float it doesn’t compile
Arduino: 1.8.13 (Windows 10), Board: “Arduino NANO 33 IoT”
sketch\BlynkTest2.ino.cpp.o: In function `void BlynkApi<BlynkProtocol<BlynkArduinoClientGenarduino::Client > >::virtualWrite(int, float)’:
C:\Users\Toomas\Documents\Arduino\libraries\Blynk\src/Blynk/BlynkParam.h:393: undefined reference to `dtostrf_internal(double, signed char, unsigned char, char*)’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino NANO 33 IoT.
Any idea?
@vshymanskyy this seems to be the same issue as reported here…
If you want something other than what’s below, you’ll need to tell us how to make it appear…
Processing mkrnb1500 (platform: atmelsam; board: mkrnb1500; framework: arduino)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/mkrnb1500.html
PLATFORM: Atmel SAM (8.1.0) > Arduino MKR NB 1500
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Fl…
It seems that some board types don’t support the use of float values in the Blynk.virtualWrite(vPin, value) command.
Have you tried using the blynk library, which is one step lower?
Thanks for bringing it to my attention. I’ll re-check it asap
We fixed the issue. The timing is perfect - I’m working on a new maintenance release which should be out somewhere next week.
For now, you can download the latest/unreleased library from github master branch: https://github.com/blynkkk/blynk-library/archive/refs/heads/master.zip
I can confirm that it works now.
Tanks a lot
