Hi guys. I have an big issue when I started trying to use the SIM900 with Blynk.
Here is my Code
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
char auth[] = "MYAUTH";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "iliad";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
delay(3000);
// Set GSM module baud rate
SerialAT.begin(19200);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
So the code seems to be ok but the output no. Below there is the output:
[16253]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.4 on Arduino Uno
[16348] Modem init...
[26614] Cannot init
[16254]
___ __ __
[16349] Modem init...
[26615] Cannot init
I connected all, also the shared ground. I hope that you can solve this problem.
