My router blocked Blynk
I have problem with my router, when I connect blynk through Wi-Fi network the process stops at “ waiting for device online”, and when I connect it with another Wi-Fi network the process done smoothly.
Anyone faced with the same problem and have a solution for it?
The image for the router model.
If your router has an inbuilt firewall it may be blocking the traffic. You can just reset router entirely and see if it solves the problem.
Nice job of sharing your router’s credentials!
Most likely it’s your ISP rather than your actual router that’s the issue.
The credentials are changed Mr Pete
Thank you
Not necessary.
Is this router on the same network?
No Sir
As @PeteKnight said your ISP is blocking the Blynk traffic.
