i have read in a thread: All relay turns on automatically when my nodemcu reboot, that this was solved, but i didn’t really understand how this was solved, i have the same problem, but can you please explain more and how to solve this?
i dont have this in my code:
void setup(){
Blynk.syncAll();
This is the problem?, or it was a local server problem?
Hi Ahmad,
If your problem is not solved yet, may it is a hardware related problem.
In case of you are using a transistor controlled relay, most important to grounding transistor base with ~10k resistor like in this example picture what I have created for you:
