My project "nodeMCU" stop connecting after v0.5.1 update
@Dmytro
Hi
my project “nodeMCU” stop connecting after v0.5.1 update
All was OK until version v0.5.0
I am using <ArduinoOTA.h> and “fauxmoESP.h” for my Echo Dot.
[1053] Connected to WiFi
[1053] IP: 192.168.xx.xx
[1053]
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.5.0 on NodeMCU
[1059] Connecting to 192.168.xx.xx
[1114] Ready (ping: 18ms).
[6115] Connecting to 192.168.xx.xx
[6130] Ready (ping: 10ms).
HTTP/1.1 200 OK
CACHE-CONTROL: max-age=86400
DATE: Mon, 22 Jun 2015 17:24:01 GMT
EXT:
OPT: "http://schemas.upnp.org/upnp/1/0/"; ns=01
01-NLS: 4445561AC5Cxxx
SERVER: Unspecified, UPnP/1.0, Unspecified
X-User-Agent: redsonic
ST: urn:Belkin:service:basicevent:1
USN: uuid:Socket-1_0-4445561AC5C600::urn:Belkin:service:basicevent:1
HTTP/1.1 200 OK
EXT:
USN: uuid:Socket-1_0-4445561AC5Cxxx::urn:Belkin:service:basicevent:1
this is my loop section
/*----------------------------------Loop--------------------------------------*/
    ArduinoOTA.handle();
    timer.run(); // Initiates Blynk Timer
    timer1.run();
    fauxmo.handle();
    if (mySwitch.available()) { RF315();}
now I returned back to v0.5.0
any suggestion ?
A lot of discuss were taking place in last few days, yet still it is somehow easier to write, than to read… Port has changed from 8442 to 80 (or is it 8080?)
For local servers.
Ah yes… At least for me the easiest (temporary) solution was to change it back to 8442, till all devices will receive “update”
#define BLYNK_DEFAULT_PORT 8442
You need to use 8080. 8442 will be dropped with next update for the local server.
OK, then I will… I haven’t been reading that far, and 8442 is a temporary fix for other library “tweaks” last night :wink: To be honest I was confused for about 20 minutes too before I reminded myself about changes in 0.5.1 - till yesterday I was using 0.4.8.
OK now
I just added the 8080 port to my local server
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, LOCAL_SERVER ,8080);
my setup
   /*--------------------------------Setup --------------------------------------*/
        WiFi.mode(WIFI_STA);  // Set WIFI module to STA mode
      Serial.begin(115200);   // See the connection status in Serial Monitor
      #ifdef LOCAL_SERVER
      #else
        Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, Geo_DNS_SERVER);
      #endif
        while (Blynk.connect() == false) {}
        ArduinoOTA.setHostname(OTA_HOSTNAME);
        ArduinoOTA.begin();
