So my projects should open and close garage door while streaming video.
i can get my device online in blynk but no video streaming.
My code
#define BLYNK_TEMPLATE_ID "TMPL4II0o1LQe"
#define BLYNK_TEMPLATE_NAME "Esp32"
#define BLYNK_AUTH_TOKEN "naXn3qkovXDW7o6W-vYjUUf5aT9XtUAH"
char ssid[] = "mano wifi";
char pass[] = "gycio wifi";
bool fetch_blynk_state = true; //true or false
//#define BLYNK_PRINT Serial
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <AceButton.h>
#include "esp_camera.h"
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "soc/soc.h" //disable brownout problems
#include "soc/rtc_cntl_reg.h" //disable brownout problems
#include "esp_http_server.h"
using namespace ace_button;
#define PART_BOUNDARY "123456789000000000000987654321"
// This project was tested with the AI Thinker Model, M5STACK PSRAM Model and M5STACK WITHOUT PSRAM
#define CAMERA_MODEL_AI_THINKER
#if defined(CAMERA_MODEL_WROVER_KIT)
#define PWDN_GPIO_NUM -1
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 21
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 19
#define Y4_GPIO_NUM 18
#define Y3_GPIO_NUM 5
#define Y2_GPIO_NUM 4
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#elif defined(CAMERA_MODEL_M5STACK_PSRAM)
#define RESET_GPIO_NUM 15
#define XCLK_GPIO_NUM 27
#define SIOD_GPIO_NUM 25
#define SIOC_GPIO_NUM 23
#define Y9_GPIO_NUM 19
#define Y8_GPIO_NUM 36
#define Y7_GPIO_NUM 18
#define Y6_GPIO_NUM 39
#define Y5_GPIO_NUM 5
#define Y4_GPIO_NUM 34
#define Y3_GPIO_NUM 35
#define Y2_GPIO_NUM 32
#define VSYNC_GPIO_NUM 22
#define HREF_GPIO_NUM 26
#define PCLK_GPIO_NUM 21
#elif defined(CAMERA_MODEL_M5STACK_WITHOUT_PSRAM)
#define Y2_GPIO_NUM 17
#elif defined(CAMERA_MODEL_AI_THINKER)
#define PWDN_GPIO_NUM 32
#define XCLK_GPIO_NUM 0
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#else
#error "Camera model not selected"
#endif
// define the GPIO connected with Relays and switches
#define RelayPin1 12 //D12
#define RelayPin2 13 //D13
#define SwitchPin1 14 //D14
#define SwitchPin2 15 //D15
#define wifiLed 2 //D2
//Change the virtual pins according the rooms
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
int wifiFlag = 0;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1)
toggleState_1 = param.asInt();
digitalWrite(RelayPin1, !toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2)
toggleState_2 = param.asInt();
digitalWrite(RelayPin2, !toggleState_2);
void checkBlynkStatus()
{ // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false)
wifiFlag = 1;
Serial.println("Blynk Not Connected");
digitalWrite(wifiLed, LOW);
if (isconnected == true)
wifiFlag = 0;
if (!fetch_blynk_state)
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
digitalWrite(wifiLed, HIGH);
Serial.println("Blynk Connected");
BLYNK_CONNECTED()
if (fetch_blynk_state)
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
button1.init(SwitchPin1);
button2.init(SwitchPin2);
Blynk.begin(auth, ssid, pass); // modified
WiFi.begin(ssid, pass);
timer.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 2 seconds
Blynk.config(auth);
if (!fetch_blynk_state) {
camera_config_t config;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
button1.check();
button2.check();
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
static esp_err_t stream_handler(httpd_req_t *req){
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK){
return res;
while(true){
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
res = ESP_FAIL;
if(fb->width > 400){
if(fb->format != PIXFORMAT_JPEG){
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
esp_camera_fb_return(fb);
fb = NULL;
if(!jpeg_converted){
Serial.println("JPEG compression failed");
res = ESP_FAIL;
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
if(res == ESP_OK){
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK){
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(fb){
fb = NULL;
_jpg_buf = NULL;
} else if(_jpg_buf){
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
//Serial.printf("MJPG: %uB\n",(uint32_t)(_jpg_buf_len));
return res;
void startCameraServer(){
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
config.server_port = 80;
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
//Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &index_uri);
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState)
Serial.println("EVENT1");
switch (eventType)
case AceButton::kEventReleased:
Serial.println("kEventReleased");
digitalWrite(RelayPin1, toggleState_1);
toggleState_1 = !toggleState_1;
break;
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState)
Serial.println("EVENT2");
switch (eventType)
digitalWrite(RelayPin2, toggleState_2);
toggleState_2 = !toggleState_2;
break;
@Gytis Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thank You for respons i edited my post.
Your code is a mashup of stuff that makes no sense.
You don’t appear to be running the code that streams the video, but it’s difficult to tell without seeing the original code.
When you have this working, and are able to view the video stream in a browser on the same network, then there are quite a few steps to go through to make the video stream accessible via the Blynk app. This has been discussed quite a few times before, if you search for recent posts regarding the ESP32 CAM board you’ll see some info on this.
So i maneged to fix my code to some extent. Now Buttons works on blynk, But my Video streaming in not. First thing i cant get the serial print to print ip address. And if i use my old ip addres i cna connect to video but no post on blynk.
#include <WiFi.h>
#include "fb_gfx.h"
#else
#endif
#define RelayPin2 2 //D2
#define wifiLed 4 //D2
#define VPIN_BUTTON_1 V0
#define VPIN_BUTTON_2 V1
// Relay State
int wifiFlag = 0;
wifiFlag = 1;
wifiFlag = 0;
BLYNK_CONNECTED()
Blynk.config(auth);
button1.check();
button2.check();
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
fb = NULL;
res = ESP_FAIL;
_jpg_buf = fb->buf;
if(res == ESP_OK){
if(res == ESP_OK){
if(res == ESP_OK){
if(fb){
fb = NULL;
_jpg_buf = NULL;
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
return res;
.uri = "/",
.method = HTTP_GET,
.user_ctx = NULL
switch (eventType)
break;
switch (eventType)
break;
Go back to your source for this sketch and see if there is a line of code that calls the startCameraServer function.
Hello Pete,
I got the reference code I used to test the camera.
My project’s deadline is coming up really soon and basically I am running out of time to make this project to work. Everything I tried only got me more error codes… And I have to leave it for now and hope I’ll find a little more time to try something.
My reference code:
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-cam-video-streaming-web-server-camera-home-assistant/
IMPORTANT!!!
- Select Board "AI Thinker ESP32-CAM"
- GPIO 0 must be connected to GND to upload a sketch
- After connecting GPIO 0 to GND, press the ESP32-CAM on-board RESET button to put your board in flashing mode
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <WiFi.h>
#include "fb_gfx.h"
//Replace with your network credentials
const char* ssid = "mano wifi";
const char* password = "gycio wifi";
//#define CAMERA_MODEL_M5STACK_PSRAM
//#define CAMERA_MODEL_M5STACK_WITHOUT_PSRAM
// Not tested with this model
//#define CAMERA_MODEL_WROVER_KIT
#else
#endif
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
fb = NULL;
res = ESP_FAIL;
_jpg_buf = fb->buf;
if(res == ESP_OK){
if(res == ESP_OK){
if(res == ESP_OK){
if(fb){
fb = NULL;
_jpg_buf = NULL;
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
return res;
.uri = "/",
.method = HTTP_GET,
.user_ctx = NULL
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
Serial.setDebugOutput(false);
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
if(psramFound()){
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
// Wi-Fi connection
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Camera Stream Ready! Go to: http://");
Serial.print(WiFi.localIP());
// Start streaming web server
startCameraServer();
delay(1);
The last line of the void setup in this “reference code” contains the command to call the startCameraServer function.
Your code is missing this line, so your sketch isn’t launching the web server that streams the video image.
You should have been able to figure this out yourself, because I already asked you about this line of code…
I think i fixed what you said, but now it doest connect to wifi?
#include <HTTP_Method.h>
#include <Uri.h>
#include <WebServer.h>
#include <dummy.h>
#include <WiFi.h>
#include "fb_gfx.h"
#else
#endif
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
fb = NULL;
res = ESP_FAIL;
_jpg_buf = fb->buf;
if(res == ESP_OK){
if(res == ESP_OK){
if(res == ESP_OK){
if(fb){
fb = NULL;
_jpg_buf = NULL;
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
return res;
// Relay State
int wifiFlag = 0;
wifiFlag = 1;
wifiFlag = 0;
BLYNK_CONNECTED()
.uri = "/",
.method = HTTP_GET,
.user_ctx = NULL
Blynk.config(auth);
// Wi-Fi connection
delay(500);
Serial.print(".");
Serial.println("");
button1.check();
button2.check();
switch (eventType)
break;
switch (eventType)
break;
Your mashup of code is probably responsible for that.
I’d start by removing your Blynk.begin command.
Okey i removed Blynk.begin.
But still not connecting to wifi
in serial monitor:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
Do you have anything connected to your board other than the USB cable and the camera?
It appears that something is preventing your board from booting into run mode.
I have relay module.
i tried fixing up my code:
#include <Uri.h>
#include <dummy.h>
#include <WiFi.h>
#include "fb_gfx.h"
#else
#endif
if(res != ESP_OK){
return res;
while(true){
if (!fb) {
res = ESP_FAIL;
fb = NULL;
res = ESP_FAIL;
_jpg_buf = fb->buf;
if(res == ESP_OK){
if(res == ESP_OK){
if(res == ESP_OK){
if(fb){
fb = NULL;
_jpg_buf = NULL;
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK){
break;
return res;
// Relay State
int wifiFlag = 0;
wifiFlag = 1;
wifiFlag = 0;
BLYNK_CONNECTED()
.uri = "/",
.method = HTTP_GET,
.user_ctx = NULL
Blynk.config(auth);
Serial.println("");
And have you tried disconnecting it and seeing if that allows your board to boot?
I tried it doest help.
If that’s all you’re seeing in your serial monitor and you have nothing connected other than the camera and the USB cable then you appear to have a hardware problem.
i got it to next stage ![]()
Serial monitor displaying this:
entry 0x400805f0
WiFi connected
Camera Stream Ready! Go to: http://0.0.0.0Blynk Not Connected
Blynk Not Connected
Blynk Not Connected
in my code i added
Your latest code…
Your previous code…
Your board doesn’t appear to be getting an IP address, probably because of what you’ve done above with the WiFi connection part of your void loop.
You should also add:
near the top of your sketch, it will give you more info about the Blynk connection process and status.
