I am working with NodeMCU and wrote this code, everything was working fine and smooth then all of a sudden it stopped working! Is something wrong with my code? When I comment out the void loop() part it works fine again, but with the void loop() included in the code the app keeps displaying device disconnected! (I think something is wrong with the code inside the void loop() ).
@Dmitriy (mentioned you as I am new here and dont know much about anybody else)
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
This example runs directly on NodeMCU.
Please be sure to select the right NodeMCU module
in the Tools -> Board menu!
For advanced settings please follow ESP examples :
- ESP8266_Standalone_Manual_IP.ino
- ESP8266_Standalone_SmartConfig.ino
- ESP8266_Standalone_SSL.ino
#include <Servo.h>
Servo servo;
int lightState;
int state;
int cstate;
int sensorPin = A0;
int ledPin = D5;
int ledPin2 = D6;
int ledPin3 = D7;
int ledPin4 = D4;
int ledPin5 = D2;
WidgetLCD lcd(V3);
WidgetLED led1(V2);
WidgetLED led2(V1);
char auth[] = "466057f0b46a47a*************************";
char ssid[] = "************";
char pass[] = "***************************";
BLYNK_WRITE(V5)
servo.write(param.asInt());
led2.on();
int val=param.asInt();
if(val>=176)
//Blynk.virtualWrite(V7, 0);
//lcd.clear();
//lcd.print(0, 0, "Curtains Closed");
Blynk.setProperty(V1, "color", "#FF0000");
//Blynk.virtualWrite(V7, 1);
//lcd.clear();
//lcd.print(0, 0, "Curtains Open");
Blynk.setProperty(V1, "color", "#14db1a");
BLYNK_WRITE(V4)
int pinData = param.asInt();
led1.on();
if(pinData==1)
digitalWrite(ledPin, HIGH);
//Blynk.virtualWrite(V6, pinData);
Blynk.setProperty(V2, "color", "#14db1a");
//lcd.print(0,1," ");
//lcd.print(0,1,"Lights On");
digitalWrite(ledPin, LOW);
Blynk.setProperty(V2, "color", "#FF0000");
//lcd.print(0,1,"Lights Off");
lcd.clear();
servo.attach(D8);
pinMode(ledPin, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
pinMode(ledPin5, OUTPUT);
state=analogRead(sensorPin);
lightState=digitalRead(ledPin);
lcd.print(0,0,"Luminosity:");
lcd.print(11,0,state);
if (state<=50)
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
digitalWrite(ledPin4, HIGH);
digitalWrite(ledPin5, HIGH);
servo.write(178);
lcd.print(0,1," ");
lcd.print(0,1,"Curtains Closed");
lcd.print(0,1," ");
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
digitalWrite(ledPin5, LOW);
servo.write(2);
lcd.print(0,1," ");
lcd.print(0,1,"Curtains Open");
lcd.print(0,1," ");
