Hi everyone, i’m currently doing my iot mini project but, it seems like i can’t connect it to blynk. I can connect it to blynk at the first time after i finnished prototype it, but yesterday when i test it again, it became like this. Anyone know how to solve this?
#define BLYNK_TEMPLATE_ID "TMPL6JSJXk23b"
#define BLYNK_TEMPLATE_NAME "UltraS"
#define BLYNK_AUTH_TOKEN "UyCAchfCC_n7CgAnDAwMfCaBCNsWUPC4"
char auth[]=BLYNK_AUTH_TOKEN;
char ssid[]="***";
char pass[]="***";
float cm=0;
int triggerPin=5;//D6
int echoPin=4;//D7
int buzz=16; //D0
int led=15;//D8
int gSense=A0;
int TH=400;
long readDis(int triggerPin, int echoPin)
pinMode(triggerPin, OUTPUT);
digitalWrite(triggerPin, LOW);
delayMicroseconds(2);
digitalWrite(triggerPin, HIGH);
delayMicroseconds(10);
pinMode(echoPin, INPUT);
return pulseIn(echoPin, HIGH);
void sendGSense()
int data = analogRead(gSense);
Blynk.virtualWrite(V0,data);
Serial.print("MQ4: ");
Serial.println(data);
if(data>TH)
if(cm>=1200)
Blynk.logEvent("gas_alert","Gas detected, quickly close the gas stove!!!");
void sendDisSense()
int data2 = cm;
Blynk.virtualWrite(V2,data2);
Serial.print("Ultrasonic: ");
Serial.println(data2);
Blynk.begin(auth,ssid,pass,"blynk-cloud.com",8080);
timer.setInterval(2500L,sendGSense);
timer.setInterval(2500L,sendDisSense);
pinMode(gSense,INPUT);
pinMode(buzz,OUTPUT);
pinMode(led,OUTPUT);
cm = 0.01723 * readDis(triggerPin,echoPin);
Serial.print(cm);
Serial.println("cm");
int gState=analogRead(gSense);
Serial.print("Gas state: ");
Serial.println(gState);
if(cm>=1000)
if(gState>TH)
digitalWrite(led,HIGH);
tone(buzz,1000);
delay(100);
digitalWrite(led,LOW);
noTone(buzz);
delay(100);
else if(gState<=TH)
noTone(buzz);
else if(cm<1000)
if(gState>TH)
delay(100);
Serial.println("Warning!!! Warning!!! Smoke and gas detected!!!");
Serial.println("Quickly close yer gas stove!!!");
Serial.println("\t");
delay(200);
else if(gState<=TH)
Serial.println("This place is safe");
delay(200);
and now this happens:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
�U�[76] Connecting to ***
[4407] Connected to WiFi
[4407] IP: 192.168.1.188
[4407]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.8 on Arduino
[4484] Connecting to blynk-cloud.com:8080
Soft WDT reset
Exception (4):
epc1=0x4000dd24 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
>>>stack>>>
ctx: cont
sp: 3ffffd70 end: 3fffffd0 offset: 0160
3ffffed0: 000011b1 00000000 3ffe8640 0000000f
3ffffee0: 00000000 0062cd1c 00002327 00000000
3ffffef0: 00000000 0000194b 072b020c 00000000
3fffff00: 00002327 00000000 0000194b 4020484d
3fffff10: 00000000 0000194b 083126e9 001d3ec1
3fffff20: 00000000 0000194b 06666666 00001183
3fffff30: 00002327 0000194b 00000000 402055b4
3fffff40: 00002327 00000000 3ffeee34 402011bd
3fffff50: 00002327 00000000 3ffeee10 40201a34
3fffff60: 00000000 0000194b 05a1cac0 001d3ebe
3fffff70: 00000027 0000008c 3ffeeea4 00001183
3fffff80: 00002327 3ffeee10 00000000 40202210
3fffff90: 40207fb4 bc01a8c0 feefeffe feefeffe
3fffffa0: feefeffe feefeffe feefeffe 3ffef02c
3fffffb0: 3fffdad0 00000000 3ffef000 402048f4
3fffffc0: feefeffe feefeffe 3fffdab0 4010130d
<<<stack<<<
