Hi All,
In the blynk could created a templated then and by using template id and pass, i kept in a code and uploaded to my ESP32 board, below is the code and remaining details, after upload done successfully, then i try to configure using blynk app, it was not finding and in my ESP32 device LED is not blinking, please help to resolve this.
this is the issue with second device but in case of my first device, it was successfully uploaded and configured, but after 1-2 days that device showing offline on my mobile and the same issue ESP 32 Device LED not blinking if click on reset, it is working for 2min then LED is just glowing not blinking.
please help me on these issues…
. Add details :
• ESp32 wifi
• Smartphone OS (Android)8.0
• Blynk server Cloud
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
* TITLE: Blynk 2.0 + IR + Manual Switch control 8 Relays using ESP32 with DHT11 sensor, LDR, Realtime Feedback & No WiFi control
* Click on the following links to learn more.
* YouTube Video: https://youtu.be/Vgyj3cCAioI
* Related Blog : https://iotcircuithub.com/esp32-projects/
* by Tech StudyCell
* Preferences--> Aditional boards Manager URLs :
* https://dl.espressif.com/dl/package_esp32_index.json, http://arduino.esp8266.com/stable/package_esp8266com_index.json
* Download Board ESP32 (1.0.6) : https://github.com/espressif/arduino-esp32
* Download the Libraries:
* Blynk 1.0.1 Library: https://github.com/blynkkk/blynk-library
* IRremote Library (3.3.0): https://github.com/Arduino-IRremote/Arduino-IRremote
* DHT Library (1.4.2): https://github.com/adafruit/DHT-sensor-library
#define BLYNK_TEMPLATE_ID "TMPLYTt1TtOx"
#define BLYNK_DEVICE_NAME "ESP32Copy"
//#define BLYNK_DEBUG
//#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
// #include <DHT.h>
#include <IRremote.h>
#define IR_RECV_PIN 35 // D35 (IR receiver pin)
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
// #define DHTTYPE DHT11 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
// #define DHTPIN 16 //D16 pin connected with DHT
#define LDR_PIN 34 //D34 pin connected with LDR
// define the GPIO connected with Relays and switches
#define RelayPin1 23 //D23
#define RelayPin2 22 //D22
#define RelayPin3 21 //D21
#define RelayPin4 19 //D19
#define RelayPin5 18 //D18
#define RelayPin6 5 //D5
#define RelayPin7 25 //D25
#define RelayPin8 26 //D26
#define SwitchPin1 13 //D13
#define SwitchPin2 12 //D12
#define SwitchPin3 14 //D14
#define SwitchPin4 27 //D27
#define SwitchPin5 33 //D33
#define SwitchPin6 32 //D32
#define SwitchPin7 15 //D15
#define SwitchPin8 4 //D4
#define wifiLed 2 //D2
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
#define VPIN_BUTTON_6 V6
#define VPIN_BUTTON_7 V7
#define VPIN_BUTTON_8 V8
#define VPIN_BUTTON_C V9
#define VPIN_TEMPERATURE V10
#define VPIN_HUMIDITY V11
#define VPIN_LDR V12
// Relay State
bool toggleState_1 = LOW; //Define integer to remember the toggle state for relay 1
bool toggleState_2 = LOW; //Define integer to remember the toggle state for relay 2
bool toggleState_3 = LOW; //Define integer to remember the toggle state for relay 3
bool toggleState_4 = LOW; //Define integer to remember the toggle state for relay 4
bool toggleState_5 = LOW; //Define integer to remember the toggle state for relay 5
bool toggleState_6 = LOW; //Define integer to remember the toggle state for relay 6
bool toggleState_7 = LOW; //Define integer to remember the toggle state for relay 7
bool toggleState_8 = LOW; //Define integer to remember the toggle state for relay 8
// Switch State
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
bool SwitchState_5 = LOW;
bool SwitchState_6 = LOW;
bool SwitchState_7 = LOW;
bool SwitchState_8 = LOW;
float temperature1 = 0;
float humidity1 = 0;
int ldrVal;
#include "BlynkEdgent.h"
BlynkTimer timer2;
// DHT dht(DHTPIN, DHTTYPE);
void readSensor(){
ldrVal = map(analogRead(LDR_PIN), 0, 4095, 10, 0);
// float h = dht.readHumidity();
// float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
// if (isnan(h) || isnan(t)) {
// Serial.println("Failed to read from DHT sensor!");
// return;
// else {
// humidity1 = h;
// temperature1 = t;
// // Serial.println(temperature1);
// // Serial.println(ldrVal);
void sendSensor()
readSensor();
Blynk.virtualWrite(VPIN_HUMIDITY, humidity1);
Blynk.virtualWrite(VPIN_TEMPERATURE, temperature1);
Blynk.virtualWrite(VPIN_LDR, ldrVal);
//BLYNK_CONNECTED() {
// // Request the latest state from the server
// Blynk.syncVirtual(VPIN_BUTTON_1);
// Blynk.syncVirtual(VPIN_BUTTON_2);
// Blynk.syncVirtual(VPIN_BUTTON_3);
// Blynk.syncVirtual(VPIN_BUTTON_4);
// Blynk.syncVirtual(VPIN_BUTTON_5);
// Blynk.syncVirtual(VPIN_BUTTON_6);
// Blynk.syncVirtual(VPIN_BUTTON_7);
// Blynk.syncVirtual(VPIN_BUTTON_8);
// Blynk.syncVirtual(VPIN_TEMPERATURE);
// Blynk.syncVirtual(VPIN_HUMIDITY);
// Blynk.syncVirtual(VPIN_LDR);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
if(toggleState_1 == 1){
digitalWrite(RelayPin1, LOW);
else {
digitalWrite(RelayPin1, HIGH);
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
if(toggleState_2 == 1){
digitalWrite(RelayPin2, LOW);
else {
digitalWrite(RelayPin2, HIGH);
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
if(toggleState_3 == 1){
digitalWrite(RelayPin3, LOW);
else {
digitalWrite(RelayPin3, HIGH);
BLYNK_WRITE(VPIN_BUTTON_4) {
toggleState_4 = param.asInt();
if(toggleState_4 == 1){
digitalWrite(RelayPin4, LOW);
else {
digitalWrite(RelayPin4, HIGH);
BLYNK_WRITE(VPIN_BUTTON_5) {
toggleState_5 = param.asInt();
if(toggleState_5 == 1){
digitalWrite(RelayPin5, LOW);
else {
digitalWrite(RelayPin5, HIGH);
BLYNK_WRITE(VPIN_BUTTON_6) {
toggleState_6 = param.asInt();
if(toggleState_6 == 1){
digitalWrite(RelayPin6, LOW);
else {
digitalWrite(RelayPin6, HIGH);
BLYNK_WRITE(VPIN_BUTTON_7) {
toggleState_7 = param.asInt();
if(toggleState_7 == 1){
digitalWrite(RelayPin7, LOW);
else {
digitalWrite(RelayPin7, HIGH);
BLYNK_WRITE(VPIN_BUTTON_8) {
toggleState_8 = param.asInt();
if(toggleState_8 == 1){
digitalWrite(RelayPin8, LOW);
else {
digitalWrite(RelayPin8, HIGH);
BLYNK_WRITE(VPIN_BUTTON_C) {
all_SwitchOff();
void all_SwitchOff(){
toggleState_1 = 0; digitalWrite(RelayPin1, HIGH); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 0; digitalWrite(RelayPin2, HIGH); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 0; digitalWrite(RelayPin3, HIGH); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_4 = 0; digitalWrite(RelayPin4, HIGH); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
toggleState_5 = 0; digitalWrite(RelayPin5, HIGH); Blynk.virtualWrite(VPIN_BUTTON_5, toggleState_5); delay(100);
toggleState_6 = 0; digitalWrite(RelayPin6, HIGH); Blynk.virtualWrite(VPIN_BUTTON_6, toggleState_6); delay(100);
toggleState_7 = 0; digitalWrite(RelayPin7, HIGH); Blynk.virtualWrite(VPIN_BUTTON_7, toggleState_7); delay(100);
toggleState_8 = 0; digitalWrite(RelayPin8, HIGH); Blynk.virtualWrite(VPIN_BUTTON_8, toggleState_8); delay(100);
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(RelayPin5, OUTPUT);
pinMode(RelayPin6, OUTPUT);
pinMode(RelayPin7, OUTPUT);
pinMode(RelayPin8, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
pinMode(SwitchPin5, INPUT_PULLUP);
pinMode(SwitchPin6, INPUT_PULLUP);
pinMode(SwitchPin7, INPUT_PULLUP);
pinMode(SwitchPin8, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
irrecv.enableIRIn(); // Enabling IR sensor
BlynkEdgent.begin();
// dht.begin();
// Setup a function to be called every 2 seconds
timer2.setInterval(2000L, sendSensor);
BlynkEdgent.run();
manual_control(); //Manual Switch Control
ir_remote(); //IR remote Control
timer2.run();
