My device was offline after several minutes online although it still update new value
My devices (Raspberry Pi 4) is offline after 1 minute online .
But it still update new value until 11pm. (I set timer for the devices sleep 4 hour a day) Moreover I set it is a startup app. (It open when the window turn on)
And here my code:
from Lib import BlynkLib
from Class import dht_class as dc
from Class import relay_class as rc
import RPi.GPIO as GPIO
import board
import time
CONNECTING = True
while (CONNECTING):
    try:
        blynk = BlynkLib.Blynk('ql4jRS1qYC1XxotnreusAjcweppnafhb')
        CONNECTING = False
    except:
        pass
    time.sleep(5)
@blynk.on('connected')
def blynk_connected():
    print("Blynk connected!")
@blynk.on('V4')
def v4_write_handler(value):
    if value[0] == '1':
        relay1.turn_on()
    else:
        relay1.turn_off()
@blynk.on('V5')
def v6_write_handler(value):
    if value[0] == '1':
        relay2.turn_on()
    else:
        relay2.turn_off()
@blynk.on('V6')
    if value[0] == '1':
        relay3.turn_on()
    else:
        relay3.turn_off()
#_______Relay pin initialization________#
Relay_Ch1 = 26
Relay_Ch2 = 20
Relay_Ch3 = 21
sensor_pin1 = board.D17
sensor_pin2 = board.D27
sensor_pin3 = board.D22
#_________Relay module initialization_________#
relay1 = rc.relay_module(Relay_Ch1)
relay2 = rc.relay_module(Relay_Ch2)
relay3 = rc.relay_module(Relay_Ch3)
#_________DHT22 sensor pin initialization_________#
sensor1 = dc.dht_module(dht_pin=sensor_pin1, relay_module=relay1)
sensor2 = dc.dht_module(dht_pin=sensor_pin2, relay_module=relay2)
sensor3 = dc.dht_module(dht_pin=sensor_pin3, relay_module=relay3)
def safe_write(pin, value):
    try: blynk.virtual_write(pin, value)
    except: print("Error writing!")
while 1:
    blynk.run()
    sensor1.read_humid()
    sensor2.read_humid()
    sensor3.read_humid()
    sensor1.write_online(virtual_pin=1)
    sensor2.write_online(virtual_pin=2)
    sensor3.write_online(virtual_pin=3)
    time.sleep(300)
    state_list = [sensor1.relay.status, sensor2.relay.status, sensor3.relay.status]
    print(state_list)
    if sensor1.last_humid < 82 and state_list[1] is False and state_list[2] is False:
        sensor1.relay.turn_on()
        # blynk.virtual_write(4,1)
        safe_write(4,1)
        continue
    elif sensor1.last_humid >= 88:
        sensor1.relay.turn_off()
        # blynk.virtual_write(4,0)
        safe_write(4,0)
    if sensor2.last_humid < 82 and state_list[0] is False and state_list[2] is False:
        sensor2.relay.turn_on()
        # blynk.virtual_write(5,1)
        safe_write(5,1)
        continue
    elif sensor2.last_humid >= 88:
        sensor2.relay.turn_off()
        # blynk.virtual_write(5,0)
        safe_write(5,0)
    if sensor3.last_humid < 80 and state_list[1] is False and state_list[0] is False:
        sensor3.relay.turn_on()
        # blynk.virtual_write(6,1)
        safe_write(6,1)
        continue
    elif sensor3.last_humid >= 88:
        sensor3.relay.turn_off()
        # blynk.virtual_write(6,0)
        safe_write(6,0)
I know that the device is still working is good, but my devices is set up far from me so I don’t know when it is offline real or fake.
This value was updated until the device went to sleep.
Library version?
Serial output?
I use library version 1.0 and here my serial output.
Copy and paste the text from your serial monitor and paste it with triple backticks, the same as you did with your code.
