Currently i using ESP-01 WiFi Serial Transceiver Module (ESP8266) + Arduino UNO to make my project, I am not using the AT firmware for esp but i do write the code inside. And communicate with Arduino UNO via serial communication. Blynk is work, I send signal to esp every second and esp does the virtualWrite but after around 1 hour or 2 hours, it stack. I tried many way to solve but no luck. I need help. Thanks
Panic core_esp8266_main.cpp:215 loop_task
stack>>>
ctx: sys
sp: 3fffeee0 end: 3fffffb0 offset: 0000
3fffeee0: 00000000 5293929a 40238adb 3ffe9434
3fffeef0: 000000fe 00000000 00000000 00000000
3fffef00: 00000000 00000000 00000000 3ffef15c
3fffef10: 80000000 3fffd9d0 3ffee7f0 3ffef114
3fffef20: 3fffdad0 00000000 3ffe85e0 40208c26
3fffef30: 4023dade 3fffdab0 00000000 40208c93
3fffef40: 00000000 3fffdad0 3ffef114 402085d0
3fffef50: 40000f49 40000f49 3fffdab0 40000f49
3fffef60: 40000e19 0004c0dd 00000000 00000005
3fffef70: 60000600 aa55aa55 000000f5 40105749
3fffef80: 4010574f 00000000 00000005 40100a00
3fffef90: 4010000d a929af98 0004c0dd 401000ac
3fffefa0: 4022de18 3fffef3c 4022ddd1 3ffff3e8
3fffefb0: 00000005 00000000 00000020 4010018c
3fffefc0: 00000005 00000000 000000j⸮ł⸮j4˫⸮’HYY⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮2⸮⸮⸮⸮88 401023b4
3fffefe0: 40102f3b 3ffed088 3ffed0b0 000000fc
3fffeff0: 00000051 083f3452 3ffed9a4 40103118
3ffff000: 3ffe9ec4 00000000 00000000 4010018c
3ffff010: 00000051 083f3452 401035d2 00000100
3ffff020: 3ffe9ec4 7fffffff 00002200 00000001
3ffff030: 00000001 00000080 00000020 4010018c
3ffff040: 3ffe9ec4 f5babe31 00000005 083f3452
3ffff050: 3ffe9edc 2c9f0300 4000050c 3fffc278
3ffff060: 401032f4 3fffc200 00000022 00000100
3ffff070: 402113c5 00000030 00000020 ffffffff
3ffff080: 40211c82 3ffe8368 00000001 00000000
3ffff090: 40310000 3ffff1c0 3ffff1c4 49002e29
3ffff0a0: 00000090 00000007 3ffff363 3ffe8368
3ffff0b0: 00000001 3ffeffac 3ffe8368 00000030
3ffff0c0: 40210a23 00000030 0000001f ffffffff
3ffff0d0: 40210a0d 00000002 3ffff2c8 3ffff260
3ffff0e0: 3fdffffe 00000001 00000001 001ffffe
3ffff0f0:
The main is shown below, *it is not the entire code
unsigned short usBaudRate = 9600;
short sVirtual_Pin = -1;
short sByte=0;
char szData[200];
short usSize = sizeof(szData);
short sIsDone = 0;
if(!Blynk.connected())
Serial.println("NC");
memset(szData, '\0', sizeof(szData));
/*if(Serial.available()) //ok punya
szData[sByte] = Serial.read();
//sByte++;
//delay(2);
//Read Serial Data
gultimeout = millis();
if(gusSerialByteIndex < usSize)
gszSerialData[gusSerialByteIndex] = Serial.read();
gusSerialByteIndex++;
Serial.read();
if(gusSerialByteIndex > 0)
if((millis() - gultimeout) >= SERIAL_READ_TIME) //if over time, reset
sByte = gusSerialByteIndex;
gusSerialByteIndex = 0;
sIsDone = 1;
strcpy(szData, gszSerialData);
memset(gszSerialData, '\0', sizeof(gszSerialData));
//sByte = sRead_Serial_Data(szData, sizeof(szData));
if(sByte>0)
// Serial.print("sByte: ");
// Serial.print(sByte);
// Serial.print(", szData: ");
// Serial.println(szData);
if(strncmp(szData, "!SW-",4) == 0)
char szVData1[30];
char szVData2[30];
char szVData3[30];
char szVData4[30];
memset(szVData1, '\0', sizeof(szVData1));
memset(szVData2, '\0', sizeof(szVData2));
memset(szVData3, '\0', sizeof(szVData3));
memset(szVData4, '\0', sizeof(szVData4));
if(sGet_VirtualWrite_StringData(szData, sVirtual_Pin, szVData1, szVData2, szVData3, szVData4) == OK)
// Serial.print("sVirtual_Pin: ");
// Serial.print(sVirtual_Pin);
// Serial.print(", szVData1: ");
// Serial.print(szVData1);
// Serial.print(", szVData2: ");
// Serial.print(szVData2);
// Serial.print(", szVData3: ");
// Serial.print(szVData3);
// Serial.print(", szVData4: ");
// Serial.println(szVData4);
if((sVirtual_Pin >= 0) && (szVData1[0] != '\0'))
if(szVData4[0] != '\0')
Blynk.virtualWrite(sVirtual_Pin, szVData1, szVData2, szVData3, szVData4);
else if(szVData3[0] != '\0')
Blynk.virtualWrite(sVirtual_Pin, szVData1, szVData2, szVData3);
else if(szVData2[0] != '\0')
Blynk.virtualWrite(sVirtual_Pin, szVData1, szVData2);
else if(szVData1[0] != '\0')
Blynk.virtualWrite(sVirtual_Pin, szVData1);
Serial.println("OK");
Serial.println("NOK");
else if(strncmp(szData, "!DW-",4) == 0)
double dValue1 = -9999.99;
double dValue2 = -9999.99;
double dValue3 = -9999.99;
double dValue4 = -9999.99;
if(sGet_VirtualWrite_DoubleData(szData, sVirtual_Pin, dValue1, dValue2, dValue3, dValue4) == OK)
// Serial.print(", dValue1: ");
// Serial.print(dValue1);
// Serial.print(", dValue2: ");
// Serial.print(dValue2);
// Serial.print(", dValue3: ");
// Serial.print(dValue3);
// Serial.print(", dValue4: ");
// Serial.println(dValue4);
if((sVirtual_Pin >= 0) && (dValue1 != -9999.99))
if(dValue4 != -9999.99)
Blynk.virtualWrite(sVirtual_Pin, dValue1, dValue2, dValue3, dValue4);
else if(dValue3 != -9999.99)
Blynk.virtualWrite(sVirtual_Pin, dValue1, dValue2, dValue3);
else if(dValue2 != -9999.99)
Blynk.virtualWrite(sVirtual_Pin, dValue1, dValue2);
else if(dValue1 != -9999.99)
Blynk.virtualWrite(sVirtual_Pin, dValue1);
delay(100);
ESP.wdtFeed();
short sGet_VirtualWrite_DoubleData(char *szData, short &sVirtual_Pin, double &dValue1, double &dValue2, double &dValue3, double &dValue4)
short sStatus = NOK;
char szDummyData[30];
unsigned short usExit = 0;
short k=0;
short i=4;
short sNumData = 0;
memset(szDummyData, '\0', sizeof(szDummyData));
do
if(*(szData+i) == '\0')
usExit = 1;
else if(*(szData+i) == ',')
if(sNumData == 0)
sVirtual_Pin = atoi(szDummyData);
k=0;
sNumData++;
else if(sNumData == 1)
dValue1 = atof(szDummyData);
k=0;
sNumData++;
else if(sNumData == 2)
dValue2 = atof(szDummyData);
k=0;
sNumData++;
else if(sNumData == 3)
dValue3 = atof(szDummyData);
k=0;
sNumData++;
else if(sNumData == 4)
dValue4 = atof(szDummyData);
k=0;
sNumData++;
usExit = 1;
szDummyData[k] = *(szData+i);
k++;
i++;
ESP.wdtFeed();
}while(usExit == 0);
if(sVirtual_Pin > -1 && sVirtual_Pin < 128)
sStatus = OK;
return sStatus;
