Multiple Physical Button Feedback
Hi guys i’m new to arduino.
I’m working on a project, basically a dashboard of all the information i would need in my house, including a remote starter for my generator.
I live in haiti so we rely generaly on 3 power sources: The Grid, a Diesel generator, and an Inverter.
I was able to remotely turn on and off my generator with a simple relay shield. But I now i need feed back from my arduino to know which power source is on.
I’m using simple relays to make contact and act as buttons to turn on virtual LEDs on the blynk app, but i’m only able to make 1 LED work.
Please take a look at my code and let me know what I should fix.
Thanks,
Fredo
#include <Ethernet.h>
char auth[] = "8d08897d16384f7a8dab7537e291720a";
// Select your pin with physical button
const int btnPin3 = 8; // pushbutton feedback GRID
const int btnPin4 = 9; // pushbutton feedback GENERATOR
const int btnPin5 = 10; // pushbutton feedback INVERTER
WidgetLED led3(V3);
WidgetLED led4(V4);
WidgetLED led5(V5);
  Blynk.begin(auth);
  // Setup physical button pin (active low)
  pinMode(btnPin3, INPUT_PULLUP);
  pinMode(btnPin4, INPUT_PULLUP);
    // Wait until connected
  timer.setInterval(500L, buttonLedWidget);
 //---PUSH
 // Setup notification button on pin 2
  pinMode(2, INPUT_PULLUP);
  // Attach pin 2 interrupt to our handler
  attachInterrupt(digitalPinToInterrupt(2), notifyOnButtonPress, CHANGE);
 //---PUSH END ---
//---UPTIME+SYNC---
BLYNK_READ(V1) // Widget in the app READs Virtal Pin V1 with the certain frequency
  // This command writes Arduino's uptime in seconds to Virtual Pin V1
  Blynk.virtualWrite(1, millis() / 1000);
// Keep this flag not to re-sync on every reconnection
bool isFirstConnect = true;
// This function will run every time Blynk connection is established
BLYNK_CONNECTED() {
  if (isFirstConnect)
    // Request Blynk server to re-send latest values for all pins
    Blynk.syncAll();
    // You can also update an individual Virtual pin like this:
    //Blynk.syncVirtual(V0);
    isFirstConnect = false;
//---UPTIME+SYNC END ---
//--- PUSH ---
void notifyOnButtonPress()
  // Invert state, since button is "Active LOW"
  int isButtonPressed = !digitalRead(2);
  if (isButtonPressed) {
    Blynk.notify("YO BAY LI!");
//--- PUSH END ---
// V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
  // Read button
  boolean isPressed = (digitalRead(btnPin3) == LOW);
  // If state has changed...
  if (isPressed != btnState) {
    if (isPressed) {
      led3.on();
      led3.off();
    btnState = isPressed;
    boolean isPressed = (digitalRead(btnPin4) == LOW);
    if (isPressed) {
      led4.on();
      led4.off();
//--LED NOTIFICATION ON PRESS
Hello.
This code seems wrong. I recommend you to create 1 method for
  // Read button
    if (isPressed) {
      led3.on();
      led3.off();
And just pass different arguments. It will be easier to read and less chance for mistake.
@Dimitriy
Thank you I figured out a way to make it work.
boolean btnState1 = false;
boolean btnState2 = false;
  // Read button
  boolean isPressed1 = (digitalRead(btnPin3) == LOW);
  if (isPressed1 != btnState1) {
    if (isPressed1) {
      led3.on();
      led3.off();
    btnState1 = isPressed1;
  boolean isPressed2 = (digitalRead(btnPin4) == LOW);
  if (isPressed2 != btnState2) {
    if (isPressed2) {
      led4.on();
      led4.off();
    btnState2 = isPressed2;
//--NOTIFICATION ON PRESS
