Hello everyone,
Looking for a code to show more than one LCD widget at the same time. Actually I need 3 LCD widgets for three sensors to show 3 separate information. Is there any idea how to do that please
Hello everyone,
Do you mean Blynk LCD widgets, or physical LCDs?
Yes sorry I mean widgets
Okay, well I think that LCD widgets aren’t actually a very good solution for this, as they are quite bulky and ugly, and I prefer to use labelled value widgets instead, but if you’re wedded to LCDs then the solution is quite simple…
The demo code here:
defines a single LCD widget object called lcd …
WidgetLCD lcd(V1);
then writes to it like this:
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(4, 0, "Hello"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
lcd.print(4, 1, "World");
You need to define three LCD widget objects, with different names. You could do this:
WidgetLCD lcd_1(V1);
WidgetLCD lcd_2(V2);
WidgetLCD lcd_3(V3);
and write to them like this…
lcd_1.clear();
lcd_1.print(4, 0, "This is");
lcd_1.print(4, 1, "LCD 1");
lcd_2.clear();
lcd_2.print(4, 0, "This is");
lcd_2.print(4, 1, "LCD 2");
lcd_3.clear();
lcd_3.print(4, 0, "This is");
lcd_3.print(4, 1, "LCD 3");
or you could give your LCD widget objects more meaningful names like…
WidgetLCD Temperature_LCD1(V1);
WidgetLCD Humidity_LCD(V2);
WidgetLCD Pressure_LCD(V3);
and use these names when you want to print data to them.
Thank you so much Pete for your nice and clear explanation
Abdul
