Two different leds with two different delay running parallel… is it possible?
Delay
If you use long
delay()
or send your hardware to sleep inside of theloop()
expect connection drops and downgraded performance.DON’T DO THAT:
void loop() { ... delay(1000); // this is long delay, that should be avoided other_long_operation(); ... Blynk.run(); }
Note: This also applies to the BLYNK_READ & BLYNK_WRITE handlers!
SOLUTION: If you need to perform actions in time intervals - use timers, for example BlynkTimer.
https://docs.blynk.cc/#troubleshooting-delay
Thanks for the suggestions
