Hi! Is it possible to connect say 4 arduino to rpi zero local server over usb hub?
Sounds interesting. You would obviously need to run the RPi (Linux) equivalent of the USB script. And if that does work on an RPI, then I guess you might have to test it and report back
http://help.blynk.cc/hardware-and-libraries/arduino/usb-serial
