Isbit possible that have more than one nodejs on raspberry? ( sometimes we use several account on a server so it’s maby even account need to a raspberry device! How can i do thid
S?
Not sure I understand the question… but you can have separate… threads… I guess they are called?
I know you can run a Local Server and a Client (instead of an external MCU) at the same time… so you could probably also run multiple clients… as long as they are not trying to share GPIO resources, as I don’t think that is allowed in the RPi?
Blynk and RPi examples and guidance is rare for some reason (aside for Local Server, with is straightforward) so you might be treading on unknown ground for much of that… You may eventually end up telling us how to do it
