I got big amount of esp8266-01 for home automation and got lauched blynk server on debian pc on network.
So i have to use alot of projects for each esp8266-01. and a personal dashboard for each esp.
Is it possible to create one “main” dasboard for all projects or make android homescreen shortcut for each button?
Any solution?
As a suggestion, you could use one of them as a Master and the other ones as Slaves using Bridge function. This is not the same you are asking about but it could work. Is that ok for you?
Regarding shortcut, you can do something similar using Tasker with Blynk.
