Hoi
I am busy to extent my arduino nano weather station to Blynk. I have 14 values to display for now. Ik extent my nano with ESP8266 12E Dev kit.
and via Serial i receive the data in json string at the ESP al this is tested before started with blynk work oke.
The code as show below works until i enable the 5the Blynk.virtualWrite statement in the code. Then my connection on the ESP constantly restarting and also a stack dump i think.
What do i do wrong?
Chris
stack>>>
ctx: sys
sp: 3fffed90 end: 3fffffb0 offset: 01b0
3fffef40: 00000000 3fffdad0 3ffeeddc 40204fb5
3fffef50: 3ffe9080 40000f49 3fffdab0 40000f49
3fffef60: 40000e19 40001878 00000002 00000000
3fffef70: 3fffff10 aa55aa55 000000b2 40104c60
3fffef80: 40104c66 00000002 00000000 402162b4
3fffef90: 4010000d 40217720 00000064 40216fc0
3fffefa0: 40100c00 3fffef3c 40100bad 3ffff2e8
3fffefb0: 00000000 00000000 00000020 4010175e
3fffefc0: 3ffe9010 40104b3c 3ffec8e8 feefeffe
3fffefd0: 00000001 40103d5f 3ffed190 feefeffe
3fffefe0: 401041c2 feefeffe feefeffe feefeffe
3fffeff0: feefeffe feefeffe feefeffe feefeffe
3ffff000: 40103ca6 0000002b 7fffffff 00000000
3ffff010: 0000012b 00000000 3ffe9161 00000008
3ffff020: 40102b27 00080000 00000014 4022df0b
SoftwareSerial s(D6,D5);
#include <ArduinoJson.h>
char auth[] = "D52MPya59BwHinOzPCVUli";
char ssid[] = "blabla";
char pass[] = "HalloWorld";
//SimpleTimer timer;
BlynkTimer timer; // Create a Timer object called "timer"!
void sendSensorData()
StaticJsonBuffer<800> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(s);
if (root == JsonObject::invalid())
return;
float mySQMreading=root["data1"];
Blynk.virtualWrite(V1, mySQMreading);
float nelm=root["data2"];
Blynk.virtualWrite(V2, nelm);
float mlx90614ambient=root["data3"];
Blynk.virtualWrite(V3, mlx90614ambient);
float mlx90614object=root["data4"];
Blynk.virtualWrite(V4, mlx90614object);
bool raining=root["data5"];
Blynk.virtualWrite(V5, raining);
int volts=root["data6"];
Blynk.virtualWrite(V6, volts);
//float lux=root["data7"];
//Blynk.virtualWrite(V7, lux);
//int skystate=root["data8"];
//Blynk.virtualWrite(V8, skystate);
//int setpoint1=root["data9"];
//Blynk.virtualWrite(V9, setpoint1);
//int setpoint2=root["data10"];
//Blynk.virtualWrite(V10, setpoint2);
//int bme280humidity=root["data11"];
//Blynk.virtualWrite(V11, bme280humidity);
//float bme280temperature=root["data12"];
//Blynk.virtualWrite(V12, bme280temperature);
//int dewpoint=root["data13"];
//Blynk.virtualWrite(V13, dewpoint);
//int bme280pressure=root["data14"];
//Blynk.virtualWrite(V14, bme280pressure);
s.begin(9600);
timer.setInterval(1000L, sendSensorData);
