More than 10 templates w/o Pro?
Is the ONLY way to get more than 10 templates is going to the Pro plan?? I have 10 projects, need one more. All personal. Is Pro the only way? I’m currently Maker. I see you can upgrade higher maker and get 20 devices, but thats not templates correct?
99/month is a big jump from 12/month.
Yes, you’ll need to upgrade to Pro for more templates.
One possible workaround is to use the same template for multiple devices, and use tabs to control those devices…
Thank you for the replay.
I need more than 20 data streams is the core problem. Again limited by Maker tier. My solution was make another template, but I’m out of those too.
It’s for a program to monitor two miners so lots of data points. 2x(4x chips volts, 4x chip temp, 4x fans, 4x hash rate and a couple more random ones). Id like to have both machines on one template with pages or tabs, but ya…
Thanks!
You could combine multiple pieces of data into one string, then display that string on a dashboard.
So maybe one string would represent all the data for one machine, or all your temperatures are combined into one string, like this…
63.5° 72.8° 68.4° 73.8°
Might take a bit of work, but saves money!
That’s a great idea. I never thought of that! I’ll give it a try.
