Module wasn't online yet (blynk + robot arm + A.Uno( use as 5v power adapter)
Xin chào!
Em xin hỏi vấn đề này ạ.
Em đã chọn cổng 9 và board NodeMCU 1.0
Sau khi chạy code thì app thông báo thiết bị chưa được kết nối
Có ai biết tại sao không ạ?
Em cám ơn!
#include <Servo.h>
char auth[] = "2dffb009e963473fa314841ee456da5c";  //Paste your Auth Token Here
char ssid[] = "VNPT_QUACHHIEN"; //Enter your Wifi User Name
char pass[] = "hien1909"; //Enter your Wifi Password
Servo servo;
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
BLYNK_WRITE(V0)
  servo.write(param.asInt());
BLYNK_WRITE(V1)
  servo1.write(param.asInt());
BLYNK_WRITE(V2)
  servo2.write(param.asInt());
BLYNK_WRITE(V3)
  servo3.write(param.asInt());
BLYNK_WRITE(V4)
  servo4.write(param.asInt());
BLYNK_WRITE(V5)
  servo5.write(param.asInt());
  servo.attach(D0);
  servo1.attach(D1);
  servo2.attach(D2);
  servo3.attach(D3);
  servo3.attach(D4);
  servo3.attach(D5);
Hi, The sketch looks OK, can you post a copy of the Serial Monitor prints?
billd
This is not a valid Auth code.
tôi lấy nó từ gmail , why not ?
The email address that this message came from does not appear to be the regular one that the Blynk servers uses when sending out Auth tokens.
Are you using a different Blynk server?
nó chỉ hiện vậy à
tks.
These two need to be the same, and I’d suggest using 74880 for both, if you are using a NodeMCU v0.9
i used it in 1 gmail but i will make it again in other phone
oh thanks you but i used v1.0 can u suggest any band
tks.
Sorry, I don’t understand.
i used NodeMCU v1.0 and 115200 band is the right one ?
Probably 74880, but possibly 115200.
Test this by pressing the reset button and seeing which baud rate gives you a readable output - then use the same baud rate in your sketch and post your serial output.
When you post the serial output please copy/paste from the serial monitor instead of using screenshots.
04:52:55.420 -> [30075] Connecting to blynk-cloud.com:80
04:52:58.329 -> [32974] Invalid auth token
04:53:04.413 -> [39075] Connecting to blynk-cloud.com:80
04:53:04.515 -> [39161] Invalid auth token
04:53:13.415 -> [48075] Connecting to blynk-cloud.com:80
04:53:13.518 -> [48156] Invalid auth token
04:53:22.411 -> [57075] Connecting to blynk-cloud.com:80
04:53:22.514 -> [57157] Invalid auth token
Exactly as I said originally.
Are you using a cloud server provided by someone else (getblocky.com maybe?)
of course but i worried about this is NodeMCU or esp8266
sry about this basic question…
tks.
Sorry, your answer was not 100% clear to me.
Are you using a cloud server provided by a 3rd party (not Blynk)?
yes
In that case, you need to be contacting that company for support.
@Pavlo @Dmytro - you may wish to look into this, it appears that a commercial company called getblocky.com is running a Blynk cloud server.
05:29:32.399 -> [2570] Connected to WiFi
05:29:32.399 -> [2570] IP: 192.168.31.166
05:29:32.399 ->     ___  __          __
05:29:32.399 ->    / _ )/ /_ _____  / /__
05:29:32.399 ->   / _  / / // / _ \/  '_/
05:29:32.433 ->  /____/_/\_, /_//_/_/\_\
05:29:32.433 ->         /___/ v0.6.1 on NodeMCU
05:29:32.433 ->
05:29:32.433 -> [2580] Connecting to blynk-cloud.com:80
05:29:32.501 -> [2675] Invalid auth token
lần đầu tôi thấy nó hiển thị như vậy , nó có đúng không ?
tks.
You need to be contacting getblocky for support, or using the Blynk cloud servers (and buying energy for widgets if necessary)
