Me again…
Sorry, but I’m still learning and not understand everything yet…
So on computer web dashboard working fine. I have more devices in one template. So from different devices I got data and show on dashboard. Work great!
But on phone is other story. Here each device is shown and each device in template “zalivanje” has the same view. Also if I edit dashboard of one it is also change in others. This is not OK. Phone dashboard should show as web. So one dashboard for template not for device.
This is correct behavior. When you tap the developer button on your device, you are taken to the template editing mode. After editing a template, changes are added to all devices that are created from this template.
Hi
If example I have in one template more sensors (devices) and on phone dashboard all show the same dashboard it have no sense to show all. So it will be great to disable it from phone view.
The same is when one device is created only for computer dashboard and I don’t need it on my phone this will be great to mark that it don’t show on phone.
