Hey!
I am using a Arduino MKR 1400 with GSM, reading a dht22 sensor and transfer the values (humidity and temperature as strings) every 6hours. I have 3 virtual buttons to control a relay.
My dashboard in Blynk-App has
- 2x Buttons
- 1x Timer
- 1x Led
- 2x Labeled Values
- 1x Superchart (reading 2x Virtual Values from DHT22 and 1x Digital Value response)
I have read a lot in the forum about heartbeat to the blynk server, but unfortunately i see, if debugging blynk-connection, in the serial-console a send and recieve package every 1min.
The code works, but i want to save data consumption and don´t know how the sending of http api would save gsm data.
If i define the heartbeat to a different value than 10 there is no other transfer time while debugging, it is still 1min.
This is my code
#define BLYNK_PRINT Serial // Defines the object that is used for printing
#define BLYNK_DEBUG // Optional, this enables more detailed prints
#define BLYNK_PRINT SerialUSB
#include <MKRGSM.h>
#include <BlynkSimpleMKRGSM.h>
// Set Blynk heartbeat interval.
// Each heartbeat uses ~90 bytes of data.
#define BLYNK_HEARTBEAT 10 //was 10 [sek]; 300 = 5min; 1800 = 30min; 86400 =24h
GSMClient client;
GPRS gprs;
GSM gsmAccess;
#include <DHT.h>
char auth[] = "auth_token";
char pin[] = "";
char apn[] = "TM"; //hologram oder pepper oder TM
char user[] = "";
char pass[] = "";
#define DHTPIN 2 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
DHT dht(DHTPIN, DHTTYPE);
#if defined(ARDUINO_ARCH_AVR)
#define SERIAL Serial
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_SAM)
#define SERIAL SerialUSB
#else
#endif
int period = 60000; //10min
unsigned long time_now = 0;
void sendSensor()
int h = dht.readHumidity();
int t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
SerialUSB.println("Failed to read from DHT sensor!");
return;
// Please don't send more than 10 values per second.
Blynk.virtualWrite(V10, h);
Blynk.virtualWrite(V11, t);
// Select your pin with physical button
const int btnPin = 1;
WidgetLED led3(V3);
// V3 LED Widget represents the physical button state
boolean btnState = false;
void buttonLedWidget()
// Read button
boolean isPressed = (digitalRead(btnPin) == LOW);
// If state has changed...
if (isPressed != btnState) {
if (isPressed) {
led3.on();
led3.off();
btnState = isPressed;
int relais_ein = 3;
int relais_state = 0;
const int led = 6;
int automatik; //V0
int hand; //V4
int zeit; //V1
int ReCnctFlag; // Reconnection Flag
int ReCnctCount = 0; // Reconnection counter
//Timer Widget digital inputs für die Verriegelung wenn dann Automatik//Zeit,- siehe loop
BLYNK_WRITE(V0)
automatik = param.asInt(); // assigning incoming value from pin V0 to a variable
BLYNK_WRITE(V4)
hand = param.asInt(); // assigning incoming value from pin V4 to a variable
// process received value
BLYNK_WRITE(V1)
zeit = param.asInt(); // assigning incoming value from pin V1 to a variable
Blynk.begin(auth, gsmAccess, gprs, client, pin, apn, user, pass);
Blynk.connect();
// Setup physical button pin (active low)
pinMode(btnPin, INPUT_PULLUP);
pinMode(relais_ein, OUTPUT);
pinMode(led, OUTPUT);
dht.begin();
timer.setInterval(5000L, buttonLedWidget);
// Setup a function to be called every 6 hours
timer.setInterval(21600000L, sendSensor); //1000L 1x per Sekunde, 1800 000L für 30min , 21 600 000L für 6h
millis();
/* if (Blynk.connected()) { // If connected run as normal
Blynk.syncAll();
} else if (ReCnctFlag == 0) { // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
ReCnctFlag = 1; // Set reconnection Flag
Serial.println("Starting reconnection timer in 30 seconds...");
timer.setTimeout(30000L, []() { // Lambda Reconnection Timer Function
ReCnctFlag = 0; // Reset reconnection Flag
ReCnctCount++; // Increment reconnection Counter
Serial.print("Attempting reconnection #");
Serial.println(ReCnctCount);
Blynk.connect(); // Try to reconnect to the server
}); // END Timer Function
if((hand == LOW) && (automatik == LOW) || (automatik == HIGH) && (zeit == HIGH)){
digitalWrite(relais_ein, LOW);
if((hand == HIGH) && (automatik == LOW) || (automatik == HIGH) && (zeit == LOW)){
digitalWrite(relais_ein, HIGH);
if(millis() >= time_now + period)
time_now += period;
float temp_hum_val[2] = {0};
if(!dht.readTempAndHumidity(temp_hum_val)){
SERIAL.print("Humidity: ");
SERIAL.print(temp_hum_val[0]);
SERIAL.print(" %\t");
SERIAL.print("Temperature: ");
SERIAL.print(temp_hum_val[1]);
SERIAL.println(" *C");
SERIAL.print("hand: ");
SERIAL.println(hand);
SERIAL.print("autom: ");
SERIAL.println(automatik);
SERIAL.print("relais: ");
SERIAL.println(digitalRead(relais_ein));
relais_state = digitalRead(relais_ein);
// Onboard-LED Pin6
if (relais_state == LOW) {
// turn LED on:
digitalWrite(led, HIGH);
// turn LED off:
digitalWrite(led, LOW);
Here is my serial-debug
15:58:04.204 -> [10857] Connecting to TM ...
15:58:06.752 -> [13385] Connected to GPRS
15:58:06.752 -> [13386] Connecting to blynk-cloud.com:80
15:58:07.596 -> [14230] <[1D|00|01|00] k43r24gmTEqGuyFNSIAbcyBXPRjQk1Zj
15:58:07.783 -> [14436] >[00|00|01|00|C8]
15:58:07.783 -> [14441] Ready (ping: 183ms).
15:58:07.783 -> [14442] Free RAM: 25903
15:58:07.877 -> [14525] <[11|00|02|00]Xver[00]0.6.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]MKR GSM 1400[00]con[00]MKRGSM[00]build[00]Sep 14 2020 15:57:45[00]
15:58:12.783 -> [19441] Connecting to blynk-cloud.com:80
15:58:13.533 -> [20172] <[1D|00|01|00] [auth_token]
15:58:13.908 -> [20561] >[00|00|01|00|C8]
15:58:13.908 -> [20566] Ready (ping: 367ms).
15:58:13.908 -> [20568] Free RAM: 25315
15:58:14.002 -> [20649] <[11|00|02|00]Xver[00]0.6.1[00]h-beat[00]60[00]buff-in[00]1024[00]dev[00]MKR GSM 1400[00]con[00]MKRGSM[00]build[00]Sep 14 2020 15:57:45[00]
15:58:14.236 -> [20878] >[00|00|02|00|C8] //i guess here is the hardware requesting pin states
15:58:19.170 -> [25836] <[14|00|03|00|08]vw[00]3[00]255 // these are the pin states
15:58:53.886 -> Humidity: 73.50 % Temperature: 24.20 *C // i call the virtual pins every min in serial
15:58:53.886 -> hand: 0
15:58:53.886 -> autom: 0
15:58:53.886 -> relais: 0
15:59:14.345 -> [80993] <[06|00|04|00|00] // what is this?- happening every 1 min
15:59:15.376 -> [82043] >[00|00|04|00|C8] // what is this?- happening every 1 min
15:59:53.892 -> Humidity: 73.70 % Temperature: 24.20 *C
15:59:53.892 -> hand: 0
15:59:53.892 -> autom: 0
15:59:53.892 -> relais: 0
16:00:14.483 -> [141122] <[06|00|05|00|00]
16:00:15.673 -> [142300] >[00|00|05|00|C8]
16:00:53.876 -> Humidity: 73.60 % Temperature: 24.20 *C
16:00:53.923 -> hand: 0
16:00:53.923 -> autom: 0
16:00:53.923 -> relais: 0
16:01:14.627 -> [201252] <[06|00|06|00|00]
16:01:15.705 -> [202351] >[00|00|06|00|C8]
Here is my dashboard
Thank you for reading!
What can i do to save gsm data consumption? (I am now at calculated 7,7MB in 31Days and want to get under 1MB, because of dataplan)
Thank you for this great piece of software!
