MKR1000 Suport?
Hello there !
I saw that the arduino mkr1000 has been included in the last library but well … in the android app, when I have to choose hardware, I can’t see the mkr1000. So I choose “generic board”. I test the connection between the arduino and my phone with this program :
#include <WiFi101.h>
#include <BlynkSimpleMKR1000.h>
// Your WiFi credentials
char pass[] = "YourPassword";        // Set to "" for open networks
WidgetLCD lcd(V1);
  // Or specify server using one of those commands:
  //Blynk.begin(auth, ssid, pass, server_ip, port);
    // Wait until connected
   lcd.clear(); //Use it to clear the LCD Widget
  lcd.print(4, 0, "Hello"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
  lcd.print(4, 1, "World");
  // Please use timed events when LCD printintg in void loop to avoid sending too many commands
  // It will cause a FLOOD Error, and connection will be dropped
the arduino is connected to the server (says “ready” in the serial) but when I launch the program on my phone, nothing happen … I have “edit” the widget just like that : switch on “advanced mode” and pin configured as pin. (I’ve tested with V1 and the result was the same)
thanks for reading !
It should work. Could you try using other widgets, other than LCD?
Maybe just a simple button?
Generic Board is no issue here…
Hi, I tested with an MKR1000 and an LCD widget and it is working fine.
It is quite simple and self-explaining, so I didn’t comment the code…
You should understand how to work with timers, but there are good examples for that.
The widget on my iphone is set to ‘advanced’ and connected to Virtual pin V1
char auth[] = "your token here ...";
char ssid[] = "your ssid here ...";
char pass[] = "your wifi access point password here ...";
WidgetLCD lcd(V1);
  while (Blynk.connect() == false) {}
  lcd.clear();
  lcd.print(0, 0, "Connected...");
  timer.setInterval(1000L, sendText);
void sendText()
  lcd.print(0, 1, "Hello World");
