I am trying to connect to the Blynk server with my MKR NB 1500 Arduino.
I was able to connect by using the example from the Blynk library called Arduino_MKRNB.
Now I want to exchange data, i.e. send values from the Arduino to the Blynk app.
For what I understand, I must use the HTTPs API, is that correct?
There is no example with NB-IoT and HTTPs API in the Blynk library, but there is one that uses the HTTPs with GSM, and I am trying to follow that one. The code is exacly the same except that I changed the connectNetwork() function to connect to NB-IoT instead of GSM (see code below).
Problem: in the Blynk app, the device is offline, even though the Arduino says it connects successfully. Thus, we cannot send nor receive data.
Please let me know if there is something that I am misunderstanding.
Features of the project:
• MKR NB 1500 with NB-IoT communication
• Android 12
• Blynk server
• Blynk Library 1.0.1
Code:
#include <MKRNB.h>
const char auth[] = "YourAuthToken";
// Blynk cloud server
const char* host = "blynk-cloud.com";
unsigned int port = 8080;
// Network settings
#define PINNUMBER ""
NBClient client;
GPRS gprs;
NB nbAccess;
// Start the GSM connection
void connectNetwork()
Serial.println("Connecting to NB...");
bool status = false;
// After starting the modem with GSM.begin()
// attach the shield to the GPRS network with the APN, login and password
while (status == false) {
if ((nbAccess.begin(PINNUMBER) == NB_READY) &
(gprs.attachGPRS() == GPRS_READY)) {
status = true;
Serial.print(".");
Serial.println();
Serial.println("NB connected");
bool httpRequest(const String& method,
const String& request,
String& response)
Serial.print(F("Connecting to "));
Serial.print(host);
Serial.print(":");
Serial.print(port);
Serial.print("... ");
if (client.connect(host, port)) {
Serial.println("OK");
Serial.println("failed");
return false;
client.print(method); client.println(F(" HTTP/1.1"));
client.print(F("Host: ")); client.println(host);
client.println(F("Connection: close"));
if (request.length()) {
client.println(F("Content-Type: application/json"));
client.print(F("Content-Length: ")); client.println(request.length());
client.println();
client.print(request);
client.println();
//Serial.println("Waiting response");
int timeout = millis() + 5000;
while (client.available() == 0) {
if (timeout - millis() < 0) {
Serial.println(">>> Client Timeout !");
client.stop();
return false;
//Serial.println("Reading response");
int contentLength = -1;
while (client.available()) {
String line = client.readStringUntil('\n');
line.trim();
line.toLowerCase();
if (line.startsWith("content-length:")) {
contentLength = line.substring(line.lastIndexOf(':') + 1).toInt();
} else if (line.length() == 0) {
break;
//Serial.println("Reading response body");
response = "";
response.reserve(contentLength + 1);
while (response.length() < contentLength && client.connected()) {
char c = client.read();
response += c;
client.stop();
return true;
Serial.println();
Serial.println();
connectNetwork();
String response;
unsigned long value = millis();
// Send value to the cloud
// similar to Blynk.virtualWrite()
Serial.print("Sending value: ");
Serial.println(value);
String putData = String("[\"") + value + "\"]";
if (httpRequest(String("PUT /") + auth + "/update/V2", putData, response)) {
if (response.length() != 0) {
Serial.print("WARNING: ");
Serial.println(response);
// Read the value back
// similar to Blynk.syncVirtual()
Serial.println("Reading value");
if (httpRequest(String("GET /") + auth + "/get/V2", "", response)) {
Serial.print("Value from server: ");
// Set Property
Serial.println("Setting property");
if (httpRequest(String("GET /") + auth + "/update/V2?label=" + value, "", response)) {
// For more HTTP API, see http://docs.blynkapi.apiary.io
// Wait
delay(30000L);
