Hi, I cant find mkr gsm 1400 device in the hardware list on my blink app
The reason for choosing a particular device in the app is do that the app deals with the pin mappings correctly.
Not a problem if you only use virtual pins anyway (although fewer virtual pins will be available if you choose ‘weaker’ hardware).
If you plan on attaching widgets to digital or analogue pins then you’ll need to do some experimentation. Start by choosing a board that is as similar as possible to the one you are using, or choose “generic board”.
ok Thank you very much for the response.I was asking because the MCU mkr gsm 1400 is in the list of supoorted devices ,but when you are creating a new project in android mobile its not listed on the list of hardware.Thank you anyway
