scrollbar missing from web dashboard. I have multiple values and unable to see all the values because no scrollbar.
Thanks for the report.
What browser version / OS do you have?
Please try to clear the browser cache. Does that help?
What’s your screen resolution?
Seems that it’s less than 1366x768
Anyway, Blynk Console supports minimum of 1280x800
I can suggest quick workaround that might be helpful till the issue is fixed after the next deployment:
- ctrl + mouse scroll (browser zoom in) until Dashboard scrollbar becomes visible;
- hover on Dashboard and scroll the mouse wheel to roll the Dashboard.
I don’t think problem is with the browser. I tries on 3 different laptops. The scrollbar appears if I expand the screen by clicking on .
I think scrollbar should appear always irrespective of browser size if all the widgets are not visible. Also lot of space is utilized here
Just checked. If I reduce the screen by clicking ctrl -, the scrollbar appears. I think it should appear by default. Thanks for the quick reply though.
Hi @rkgarg20 If you are the macOS user, the scrollbar only appears when you scroll with touch pad/Keyboard or whatever you use. Usually it’s normal behavior for mac device’s.
How do you do to get gauges 2x2, mine are 4x2
That could be done before widgets sizes rework.
Do you mean that we will never get 4X4 gauge size ?
Nope.
I mean that min size is 4x2 for gauge now.
it’s very bad, gauges are too large compare to other widgets and we cannot harmonize the graphic charter
oops, I meant 2x2 , not 4x4 !
