Missing menu button in SuperChart and Chart - export to CVS
Hello, I would like to ask you with my problem with Menu button in SuperChart. I have problem with export data from SuperChart and Chart- missing menu button for export.
I have Arduino (SEED XIAO) and SIM800 hardware, data sending every 10 sec to blynk server as V0, temperature is in float.
sensors.setResolution(9);
sensors.requestTemperatures(); // Send the command to get temperatures
float teplota = sensors.getTempCByIndex(0);
Serial.println(teplota, 2);  // + "°C");
Blynk.virtualWrite(V0, teplota);
Datastream as Double.I have Plus plan. Mobile app is Blynk IoT.
the only download report is possible via the web interface in the PC
documentation:
thank you for your help, vladimir
It’s not yet implemented in the mobile
the web dashboard has only Chart without Menu Button for export data (I have 14 widgets in web dashboard other widgets are only mobile apps?). Where can I find the SuperChart with export menu please? the documentation refers to this menu, it is wrong or old .
I´m sorry for my english… :slight_smile:
thank you
my idea was to export data for a month / week … preferably automatically (the first day of the month at 00:00) or a button from the user. the user will receive an email with an attachment or download link and import to exel.
There’s also the HTTPS API…
https://docs.blynk.io/en/blynk.cloud/get-device-report
Do you mean user dashboard? export is missing.
Does the user’s role have sufficient permissions to download reports?..
yes, is able.
vlado
Does at least one of your datastreams have the “Show in Reports” option enabled?..
yes
Just going back a couple of steps to checking the permissions, is the device owned by the user that you’re logged-in as?
If you type “reports” into the Roles and Permissions search box, it shows two categories - Owned Devices and Organization Devices:
Does your uses have access to download reports from both?
Hello Pete, yes.
I have a PLUS plan, I can’t change the rules.
my question, User must be owner device?
If yes, please, how can I do that?
vlado
You either need to give the person the Admin role, or make them the device owner - or upgrade to the PRO plan.
Or, if that isn’t going to work then maybe using the HTTPS API as I suggested earlier would be the better option.
I am a new to Blynk, I upgraded to PLUS due to data export, which unfortunately does not work according to the documentation.
I plan to move to the PRO plan when I show the customer a simple mobile environment with data export and after test operation.
A widget with an export button would be very useful, in its settings there would be a choice of export values V0, V1 …, time up to xx months, user email. In the application, I place only the export button next to the graph.
Is it possible to generate such a button from existing widgets using the API, the result will be an email with a link to download cvs data, please?
thank you, vlado
Maybe you should experiment with the API via the address bar in your browser to get a better understanding of how that works.
It’s in our plans. Mobile will have a similar actions menu that you currently see in the web.
and what should I do to make the export accessible, please? Export menu is still missing…
thx, vlado
Have you changed the user’s role to “Admin” ?
I don’t change role to Admin, but when I change owner everything is ok in PC. I don´t export data from mobile app (admin and user too).
however, the user still sees what he does not own (PC and app).
vlado
You won’t fix these issue unless you upgrade to PRO and edit the permissions of the user and staff roles, and create sub organisations.
