Merging two codes for PZEM004T and DHT 22
Please somebody guide me to merge these two codes for PZEM004T and DHT 22 to work on single ESP8266.
Code for PZEM
#include <ArduinoOTA.h>
#include <ModbusMaster.h>
#include "settingsPZEM.h"
#include <SoftwareSerial.h>  //  ( NODEMCU ESP8266 )
SoftwareSerial pzem(D5,D6);  // (RX,TX) connect to TX,RX of PZEM for NodeMCU
//SoftwareSerial pzem(D7,D8);  // (RX,TX) connect to TX,RX of PZEM
ModbusMaster node;
//WiFi data
char ssid[] = "Put your WiFi SSID here";                    //WiFi Credential
char pass[] = "Put your WiFi password here";              //WiFi Password
char server[] = "Put your Blynk local server IP address here";         //Blynk local server IP address
int port = 8080;                        //Blynk local port
#define USE_LOCAL_SERVER                //Use local Blynk Server - comment-out if use Blynk hosted cloud service
#define AUTH    "put your Blynk App Authorization code here"    //PZEM-004v3 Auth code for Blynk Local Server
int timerTask1;
double U_PR, I_PR,  P_PR,  PPR, PR_F, PR_PF, PR_alarm;
uint8_t result;  uint16_t data[6];
void setup(){
  Serial.begin(115200); Serial.println("Start serial"); pzem.begin(9600); Serial.println("Start PZEM serial");
node.begin(1, pzem);  Serial.println("Start PZEM"); // 1 = ID MODBUS
WiFi.mode(WIFI_STA);
#if defined(USE_LOCAL_SERVER)
  WiFi.begin(ssid, pass);
  Blynk.config(AUTH, server, port);
#else
  Blynk.begin(AUTH, ssid, pass);
#endif
  while (Blynk.connect() == false) {}
  ArduinoOTA.setHostname(OTA_HOSTNAME);
  ArduinoOTA.begin();
//  timerTask1 = timer.setInterval(1000, updateBlynk);
void updateBlynk() {
  Blynk.virtualWrite(vPIN_VOLTAGE,               U_PR);
  Blynk.virtualWrite(vPIN_CURRENT_USAGE,         I_PR);
  Blynk.virtualWrite(vPIN_ACTIVE_POWER,          P_PR);
  Blynk.virtualWrite(vPIN_ACTIVE_ENERGY,         PPR);
  Blynk.virtualWrite(vPIN_FREQUENCY,             PR_F);
  Blynk.virtualWrite(vPIN_POWER_FACTOR,          PR_PF);
  Blynk.virtualWrite(vPIN_OVER_POWER_ALARM,      PR_alarm);
void loop(){
//ArduinoOTA.handle();
//timer.run();
result = node.readInputRegisters(0x0000, 10);
  if (result == node.ku8MBSuccess)  {
U_PR      = (node.getResponseBuffer(0x00)/10.0f);
I_PR      = (node.getResponseBuffer(0x01)/1000.000f);
P_PR      = (node.getResponseBuffer(0x03)/10.0f);
PPR       = (node.getResponseBuffer(0x05)/1000.0f);
PR_F      = (node.getResponseBuffer(0x07)/10.0f);
PR_PF     = (node.getResponseBuffer(0x08)/100.0f);
PR_alarm  = (node.getResponseBuffer(0x09));
    Serial.print("U_PR:     "); Serial.println(U_PR);   // V
    Serial.print("I_PR:     "); Serial.println(I_PR,3);   //  A
    Serial.print("P_PR:     "); Serial.println(P_PR);   //  W
    Serial.print("PPR:      "); Serial.println(PPR,3);   // kWh
    Serial.print("PR_F:     "); Serial.println(PR_F);    // Hz
    Serial.print("PR_PF:    "); Serial.println(PR_PF);
    Serial.print("PR_alarm: "); Serial.println(PR_alarm,0);
Serial.println("====================================================");
updateBlynk();
Code for DHT22
#include <DHT.h>
char auth[] = "Your-Auth-Token";
char ssid[] = "Your-Wifi-Name";
char pass[] = "Your-Wifi-Password";
#define DHTPIN 0          // D3
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, t);
  Blynk.virtualWrite(V6, h);
  dht.begin();
Why don’t you show the already working PZEM code you achieved last time to start with:
and
It’s better to save other people some precious time.
The main issues i faced was not because the code itself.
After i installed software serial library, downgraded the Arduino core to 2.4.2 and removed the level shifter,connected the Pzem with board directly with 5V to VV of ESP and ground to G ,RX & TX with D5 and D6 of ESP.
All the codes(the one you suggested as well) started to give results.
The codes I have implemented successfully are stated below.
ModbusMaster node;
//WiFi data
int timerTask1;
void setup(){
#else
#endif
  ArduinoOTA.begin();
void loop(){
//timer.run();
updateBlynk();
The one you suggested is as below
#define USE_BLYNK_WM      0       // https://github.com/khoih-prog/Blynk_WM
#if USE_BLYNK_WM
#include <BlynkSimpleEsp8266_WM.h>
#else
#endif
//#include <SimpleTimer.h>
ModbusMaster node;
#if !USE_BLYNK_WM
//WiFi data
char ssid[] = "****";          //WiFi Credential
char pass[] = "****";          //WiFi Password
char server[] = "****";        //Blynk local server IP address
#define AUTH    "****"    //PZEM-004v3 Auth code for Blynk Local Server
#endif
int timerTask1;
#define UPDATE_INTERVAL_MS      5000
// Use 0 or 1 when you don't need to debug with many messages
#define DEBUG_LOOP              2
#define MODBUS_ID               1
void updateBlynk()
  getPZEM();
uint8_t getPZEM()
    #if (DEBUG_LOOP > 0)
    #endif
    Serial.println("PZEM: can't get data");
  #endif
  return result;
// Use this to avoid being blocked here if no WiFi
void connectWiFi(const char* ssid, const char* pass)
    Serial.println("Connecting to " + String(ssid));
    #endif
    if (pass && strlen(pass))
    } else
        WiFi.begin(ssid);
    int i = 0;
    while ((i++ < 30) && (WiFi.status() != WL_CONNECTED))
        BlynkDelay(500);
    if (WiFi.status() == WL_CONNECTED)
      Serial.println("Connected to " + String(ssid));
      Serial.println("Can't connect to " + String(ssid));
    #endif
void connectWiFiAndBlynk()
  if (WiFi.status() != WL_CONNECTED)
    connectWiFi(ssid, pass);
    Serial.println("Trying connecting to BlynkServer " + String(server));
    #endif
    Blynk.connect();
    if (Blynk.connected())
      Serial.println("Connected to BlynkServer " + String(server));
      #endif
  Serial.println("\nStart serial");
  pzem.begin(9600);
  node.begin(MODBUS_ID, pzem);
  #if USE_BLYNK_WM
    Blynk.begin();
  #else
    //connectWiFi(ssid, pass);
    connectWiFiAndBlynk();
    //Blynk.connect();
  #endif
  ArduinoOTA.begin();
  timerTask1 = timer.setInterval(UPDATE_INTERVAL_MS, updateBlynk);
After testing for continous 2 weeks, I believe the V03 of PZEM004T dont need any modification to run with ESP8266.
Sorry for misunderstanding. But IMHO, I still think that you have to fix your loop() and remove the unwanted delay().
The delay() function must be used only when it’s absolutely necessary, as it’s a waste of CPU power (unless we use it as a CPU cooler :slight_smile: ). It can create problem when we are least expected.
You can see the effect of it on the system, especially on software timers in:
Unless you’re using a preemptive multi-tasking OS, the delay() monopolizes the CPU power, yet doing nothing. It deprives all other tasks the neccessary execution to perform normally. You can try a longer delay() in the loop() and see its unwanted effect, such as Blynk disconnection, etc…
Anyway, hereafter is the suggested code to merge DHT into PZEM:
#if USE_BLYNK_WM
#else
#endif
#include <DHT.h>
ModbusMaster node;
#if !USE_BLYNK_WM
//WiFi data
char auth[]   = "****";           //PZEM-004v3 Auth code for Blynk Local Server
#endif
#define MODBUS_ID               1
#define DHTPIN        D2        // Using pin D2 for DHTxx
// Change according to your Blynk App design
#define vPIN_VOLTAGE              V0
#define vPIN_CURRENT_USAGE        V1
#define vPIN_ACTIVE_POWER         V2
#define vPIN_ACTIVE_ENERGY        V3
#define vPIN_FREQUENCY            V4
#define vPIN_POWER_FACTOR         V5
#define vPIN_OVER_POWER_ALARM     V6
#define DHT_TEMP                  V7
#define DHT_HUMIDITY              V8
float humidDHT;
float tempDHT;
void readSensor()
    return;
  humidDHT  = h;
  tempDHT   = t;
void updateBlynk()
  getPZEM();
  readSensor();
  Blynk.virtualWrite(DHT_TEMP, tempDHT);
  Blynk.virtualWrite(DHT_HUMIDITY, humidDHT);
uint8_t getPZEM()
    #endif
  #endif
  return result;
  pzem.begin(9600);
  dht.begin();
  Serial.println("Started DHT");
  #if USE_BLYNK_WM
    Blynk.begin();
  #else
    #if USE_LOCAL_SERVER
      Blynk.config(auth, server, BLYNK_HARDWARE_PORT);
    #else
      Blynk.config(auth);
    #endif
    Blynk.connect();
    if ( Blynk.connected())
      Serial.println("Connected to Blynk");
  #endif
  ArduinoOTA.begin();
Certainly, you can do it your way, and use this as an example how to merge.
Good luck again,
Bundle of thanks again, worked like a charm.
