BLYNK
Menu widget web dashboard : options not updated
my menu widget in a web dashboard does not update option labels
my python code sends labels property :
blynk.set_property(PIN_MENU, 'labels', *blist)
also tried :
blynk.set_property(PIN_MENU 'labels', "station 1", "station 2", "station 3")
widget is correctly updated on iOS app but not in web dashboard
option changes in both app and web are correctly reported the one to the other and transmitted to my server, but option labels are never updated in web dashboard
did I forget something ?
thank you
Bruno
Hello, you are doing everything right, but at the moment this feature is not implemented for the console (web dashboard), only for mobile applications
Thank you Yuliia for your answer
ok, since the menu widget is not mentioned as beta in the console editor I supposed it was working as the app widget
please also note that the label widget color property sets the text color in app, but the background color in console
it would be great to have for each widget a summary of all available properties for both app and console in the same doc page
Thanks !
Bruno
Already fixed. We’ll be avaialble with the next deploy (~week)
Agree. That’s what I was thinking recently as well.
Thank you Dmitriy for the good news !
Bruno
Ah yes found this too recently. Good news that we will be able to update the label in the drop down menu in the app and it will appear in the web widget as well. I use this function in the app to dynamically change the options in the menu widget.
I still have issues with menu widget in web dashboard : menu options are not updated
reloading web page shows update, so I think menu options are correctly transmitted but not displayed
is it supposed to be fixed ?
thanks a lot
Hello, @brunog you use Latest option in dashboard?
latest1
Hi Oleksii, thank you, yes I do
if I click on ‘Datastreams’ (or any other options) then back on ‘Dashboard’, then the widget menu shows updated options
I have the same behaviour with up to date Google Chrome and Edge browsers (win10)
Need an investigation
@brunog I checked. Real time function not implemented yet. We will try to implement it for the next deployment
Regards
ok, do you have an expected date for the next deployment ?
thank you
