I use three BLYNK_WRITE functions for Virtual pins 29, 30 & 31…
V29 with a Slider
V30 with a Menu
V31 with a Button
Button:- (I use this “Button” to Enable/Disable Alarm)
Arduino uses an initial value declared in the sketch…
Once Arduino connects to Blynk App, it promptly updates the value to Virtual Pin V31… (Immediately after the message, “[6108] Ready (ping: 219ms).”
Menu: (I use this “Menu” to set the Smoke Sensor’s Threshold Value)
Once Arduino connects to Blynk App, the threshold value in the slider doesn’t get updated and it still uses the same initial value declared in the sketch…
Slider: (I use this “Slider” to set the Fire Sensor’s Threshold Value)
To set the threshold from the menu, I had to open the menu and press “OK”…
To set the threshold from the slider, I had to touch the slider…
The issue i’m reporting here, is somewhat similar to the one in this link: http://community.blynk.cc/t/slider-widget-values-reset-to-zero-on-launch/4406
BLYNK_WRITE(V31)
// You can also use:
// int i = param.asInt() or
// double d = param.asDouble()
if (param.asInt())
Alarm = LOW;
digitalWrite(buzzPin, LOW);
Blynk.virtualWrite(1, 0); // Smoke LED
Blynk.virtualWrite(2, 0); // Fire LED
Blynk.virtualWrite(3, 0); // Temperature LED
Blynk.virtualWrite(4, 0); // Humidity LED
Alarm = HIGH;
BLYNK_WRITE(V30)
Serial.println(param.asInt());
switch (param.asInt()) {
case 1:
SmokeThreshold = 110;
break;
case 2:
SmokeThreshold = 130;
break;
case 3:
SmokeThreshold = 160;
break;
case 4:
SmokeThreshold = 180;
break;
case 5:
SmokeThreshold = 200;
break;
BLYNK_WRITE(V29)
FireThreshold = (param.asInt());
