Measuring current with esp32, blynk and acs712
Hi.
I want to measure current with esp32, acs712 sensor and blynk. I know little.
I need Arduino ide code and schematic.
Thank you.
Good luck with that, this isn’t a code factory.
Is my question wrong?
I think your concept of this community forum is wrong.
If you have an existing sketch which works with your hardware and successfully prints the data you want to the serial monitor, and you’ve created Blynk IoT account and have decided what you’d like your dashboard to look like, then sharing that will almost certainly result in you getting some help.
Ask ChatGPT.
That would be able to write a code for you .
