I can paste a String of 1000 characters into the Terminal but when I ask Terminal to repeat the String it appears to be truncated to well below 1000 characters.
Is there a setting somewhere for Terminal to display up to 1200 characters?
@Dmitriy just to add, when I started using Terminal in this particular project earlier today I think it was outputting 1000+ characters. If this is the case I suspect it relates to a combination of the maximum number of Terminal records that can be saved (default 25) and the size of each record.
So Terminal Output can be > 1000 but Terminal record storage can’t be > 25000 (25 X 1000).
Is the Terminal storage allowance included in the following default kb total from server.properties?
