I need help regarding an issue with blynk 2.0. i was working on blynk legacy the code was working fine, sensor wsa sending data and sensing the finger when i put on sensor. the problem arise when i shift to blynk 2.0. other sensors like dht11, mq135 are sending data to the blynk 2.0. but the max30100 sensor is not detecting the beat. but same sensor works with blynk legacy.
i tried this using timer library, then by calling function, then using the code in the main loop as well. but the sensor get light ON but did not respond when i put my fingre to measure heart rate and spo2.
• NodeMCU v3 + Wifi.
• Smartphone Android + version 10
• Blynk 2.0
