I’ve code for MAX30100 with esp32, how can I put an if condition to both the HR and SpO2 values to turn on the LED widget in BLYNK without disturbing the normal performance of the sensor.
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include "MAX30100.h"
#include <U8g2lib.h>
#include <Blynk.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
#define REPORTING_PERIOD_MS 1000
#define PULSE_WIDTH MAX30100_SPC_PW_1600US_16BITS
#define IR_LED_CURRENT MAX30100_LED_CURR_40MA
#define LED_CURRENT MAX30100_LED_CURR_20_8MA
#define SAMPLING_RATE MAX30100_SAMPRATE_100HZ
char auth[] = "Elas4wpj_P9t5rymrWnFQiKay2qiDxCw"; // You should get Auth Token in the Blynk App.
char ssid[] = "HiLink"; // Your WiFi credentials.
char pass[] = "kemei9911";
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
PulseOximeter pox;
MAX30100 sensor;
WidgetLED led1(V1);
uint32_t tsLastReport = 0;
uint32_t last_beat=0;
bool initialized=false;
int HRclean;
int SpO2;
void onBeatDetected()
show_beat();
last_beat=millis();
void show_beat()
u8g2.setFont(u8g2_font_7x13B_tf);
u8g2.setCursor(118,10);
u8g2.print("_");
u8g2.sendBuffer();
void initial_display()
if (not initialized)
u8g2.clearBuffer();
u8g2.setCursor(18,10);
u8g2.print("Initializing...");
u8g2.sendBuffer();
delay(3000);
initialized=true;
u8g2.clearBuffer();
if (!pox.begin()) {
u8g2.setCursor(40,12);
u8g2.print("FAILED");
u8g2.setCursor(15,29);
u8g2.print("Check Sensor !");
u8g2.sendBuffer();
for(;;);
u8g2.setCursor(20,12);
u8g2.print("INITIALIZED");
u8g2.setCursor(0,29);
u8g2.print("Put your finger...");
u8g2.sendBuffer();
delay(2000);
u8g2.begin();
initial_display();
pox.begin();
pox.setOnBeatDetectedCallback(onBeatDetected);
pox.setIRLedCurrent(LED_CURRENT);
sensor.setMode(MAX30100_MODE_SPO2_HR);
sensor.setLedsPulseWidth(PULSE_WIDTH);
sensor.setSamplingRate(SAMPLING_RATE);
pox.update();
HRclean = pox.getHeartRate();
SpO2 = pox.getSpO2();
if ((millis() - tsLastReport > REPORTING_PERIOD_MS) and (HRclean>30 and HRclean<220 and SpO2>30 and SpO2<100)) {
u8g2.clearBuffer();
u8g2.setCursor(0,12);
u8g2.print("HR");
u8g2.setCursor(70,12);
u8g2.print("Bpm");
u8g2.setCursor(0,30);
u8g2.print("SpO2 ");
u8g2.setCursor(70,30);
u8g2.print("%");
u8g2.setFont( u8g2_font_7x13B_tf );
u8g2.setCursor(45,12);
u8g2.print(HRclean);
u8g2.setCursor(45,30);
u8g2.print(SpO2);
u8g2.sendBuffer();
Blynk.virtualWrite(V5, HRclean);
Blynk.virtualWrite(V4, SpO2);
tsLastReport = millis();
