Hi there,
I have a project with ESP32 + SIM800L + NEO6M. All is working well except when I go in Blynk app on my Android. It show my location at the right place but start the screen right in the ocean near Nigeria.
To see my position I must to zoom out and search for my real location.
Is there a way to show the right location at the start of the app instead of the point that show me in the ocean?
Here is my code:
#define BLYNK_TEMPLATE_ID "xxx"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "xxx"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 15
#include <TinyGPS++.h> //https://github.com/mikalhart/TinyGPSPlus
#include <TinyGsmClient.h> //https://github.com/vshymanskyy/TinyGSM
#include <BlynkSimpleTinyGSM.h> //https://github.com/blynkkk/blynk-library
char auth[] = "xxx";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "free";
char user[] = "";
char pass[] = "";
//sender phone number with country code.
//not gsm module phone number
//const String PHONE = "Enter_Your_Phone_Number";
//GSM Module Settings
//GSM Module RX pin to ESP32 2
//GSM Module TX pin to ESP32 4
#define rxPin 16
#define txPin 17
HardwareSerial sim800(1);
TinyGsm modem(sim800);
//GPS Module Settings
//GPS Module RX pin to ESP32 17
//GPS Module TX pin to ESP32 16
#define RXD2 3
#define TXD2 1
HardwareSerial neogps(2);
TinyGPSPlus gps;
WidgetMap myMap(V0);
int pointIndex = 1;
//Set Serial monitor baud rate
Serial.println("esp32 serial initialize");
//Set GPS module baud rate
neogps.begin(9600, SERIAL_8N1, RXD2, TXD2);
Serial.println("neogps serial initialize");
//Set GSM module baud rate
sim800.begin(9600, SERIAL_8N1, rxPin, txPin);
Serial.println("SIM800L serial initialize");
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
timer.setInterval(5000L, sendToBlynk);
while(neogps.available())
if (gps.encode(neogps.read()))
sendToBlynk();
} //main loop ends
void sendToBlynk()
if (gps.location.isValid() )
//get latitude and longitude
float latitude = (gps.location.lat());
float longitude = (gps.location.lng());
//get speed
float speed = gps.speed.kmph();
//get number of satellites
float satellites = gps.satellites.value();
//Serial.print("Latitude: ");
//Serial.println(latitude, 6);
//Serial.print("Longitude: ");
//Serial.println(longitude, 6);
//Serial.print("Speed: ");
//Serial.println(speed, 6);
Blynk.virtualWrite(V1, String(latitude, 6));
Blynk.virtualWrite(V2, String(longitude, 6));
myMap.location(pointIndex, latitude, longitude, "GPS_Location");
Blynk.virtualWrite(V3, speed);
Blynk.virtualWrite(V4, satellites);
