It is possible to show Value and label on my map pin?
It is common to ask the question in the topic, not the title… I fixed it
A little bit of reading goes a long way…
http://docs.blynk.cc/#widgets-interface-map
Look at index and “value”
I would like it to show when tap on sensor.
Would like (what?) to show when you tap (where?) on sensor (what sensor?)
Very sorry.Just learning english here.
I have a sensor on this specific location.
I would like to:
- Show sensor data when tap on the map pin. (solved).
- Show sensor name when tap on the map pin.
Hope this helps.
I guess you could put your sensor name as the index and the sensor data as value.
whould the index show on the Map Pin?
I don’t know… I haven’t; messed around with the index much yet.
Thanks i will mess with it.
Looks like String Addition Operator did the trick:
String string1 = "Sensor Name: ";
String Test= string1+ MASHTEMP;
int index1 = 1;
double lat1 = 39.493836 ;
double lon1 = -121.715460 ;
myMap.location(index1, lat1, lon1, Test);
I think the index just allows you to have multiple points on the map (preferably with different locations
), like in a loop or something where you want to leave a trail. But if you want to just overwrite or move a single point, then you use the same index number.
Yes, i use a different index variable for each sensor I add to my project.
