Hello me again!
Thanks to Pet I am finishing my project I was able to add the wifimanager library after many hours … now I need help please with a detail I would like that when filling in the wifi credentials in the wifimanager AP the password is always visible, since there are router passwords They are very complicated
and it can be very difficult to write well without being able to see what one is writing, I leave the code of the library , thank you
WiFiManager is a library for the ESP8266/Arduino platform
(https://github.com/esp8266/Arduino) to enable easy
configuration and reconfiguration of WiFi credentials using a Captive Portal
inspired by:
http://www.esp8266.com/viewtopic.php?f=29&t=2520
https://github.com/chriscook8/esp-arduino-apboot
https://github.com/esp8266/Arduino/tree/master/libraries/DNSServer/examples/CaptivePortalAdvanced
Built by AlexT https://github.com/tzapu
Licensed under MIT license
#ifndef WiFiManager_h
#define WiFiManager_h
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <memory>
extern "C" {
#include "user_interface.h"
const char HTTP_HEADER[] PROGMEM = "<!DOCTYPE html><html lang=\"en\"><head><meta charset=\"UTF-8\"><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/><title>{v}</title>";
const char HTTP_STYLE[] PROGMEM = "<style>.c{text-align: center;} div,input{padding:5px;font-size:1em;} input{width:95%;} body{text-align: center;font-family:verdana;} button{border:0;border-radius:0.3rem;background-color:#1fa3ec;color:#fff;line-height:2.4rem;font-size:1.2rem;width:100%;} .q{float: right;width: 64px;text-align: right;} .l{background: url(\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAMAAABEpIrGAAAALVBMVEX///8EBwfBwsLw8PAzNjaCg4NTVVUjJiZDRUUUFxdiZGSho6OSk5Pg4eFydHTCjaf3AAAAZElEQVQ4je2NSw7AIAhEBamKn97/uMXEGBvozkWb9C2Zx4xzWykBhFAeYp9gkLyZE0zIMno9n4g19hmdY39scwqVkOXaxph0ZCXQcqxSpgQpONa59wkRDOL93eAXvimwlbPbwwVAegLS1HGfZAAAAABJRU5ErkJggg==\") no-repeat left center;background-size: 1em;}</style>";
const char HTTP_SCRIPT[] PROGMEM = "<script>function c(l){document.getElementById('s').value=l.innerText||l.textContent;document.getElementById('p').focus();}</script>";
const char HTTP_HEADER_END[] PROGMEM = "</head><body><div style='text-align:left;display:inline-block;min-width:260px;'>";
const char HTTP_PORTAL_OPTIONS[] PROGMEM = "<form action=\"/wifi\" method=\"get\"><button>Configure WiFi</button></form><br/><form action=\"/0wifi\" method=\"get\"><button>Configure WiFi (No Scan)</button></form><br/><form action=\"/i\" method=\"get\"><button>Info</button></form><br/><form action=\"/r\" method=\"post\"><button>Reset</button></form>";
const char HTTP_ITEM[] PROGMEM = "<div><a href='#p' onclick='c(this)'>{v}</a> <span class='q {i}'>{r}%</span></div>";
const char HTTP_FORM_START[] PROGMEM = "<form method='get' action='wifisave'><input id='s' name='s' length=32 placeholder='SSID'><br/><input id='p' name='p' length=64 type='PASSWORD' placeholder='PASSWORD'><br/>";
const char HTTP_FORM_PARAM[] PROGMEM = "<br/><input id='{i}' name='{n}' maxlength={l} placeholder='{p}' value='{v}' {c}>";
const char HTTP_FORM_END[] PROGMEM = "<br/><button type='submit'>GUARDAR</button></form>";
const char HTTP_SCAN_LINK[] PROGMEM = "<br/><div class=\"c\"><a href=\"/wifi\">Scan</a></div>";
const char HTTP_SAVED[] PROGMEM = "<div>Configuracion Guardada<br />NanoWifi conectandose a red wifi....<br />Si falla la conexion vuelva a intentar otra vez</div>";
const char HTTP_END[] PROGMEM = "</div></body></html>";
#ifndef WIFI_MANAGER_MAX_PARAMS
#define WIFI_MANAGER_MAX_PARAMS 10
#endif
class WiFiManagerParameter {
public:
Create custom parameters that can be added to the WiFiManager setup web page
@id is used for HTTP queries and must not contain spaces nor other special characters
WiFiManagerParameter(const char *custom);
WiFiManagerParameter(const char *id, const char *placeholder, const char *defaultValue, int length);
WiFiManagerParameter(const char *id, const char *placeholder, const char *defaultValue, int length, const char *custom);
~WiFiManagerParameter();
const char *getID();
const char *getValue();
const char *getPlaceholder();
int getValueLength();
const char *getCustomHTML();
private:
const char *_id;
const char *_placeholder;
char *_value;
int _length;
const char *_customHTML;
void init(const char *id, const char *placeholder, const char *defaultValue, int length, const char *custom);
friend class WiFiManager;
class WiFiManager
public:
WiFiManager();
~WiFiManager();
boolean autoConnect();
boolean autoConnect(char const *apName, char const *apPassword = NULL);
//if you want to always start the config portal, without trying to connect first
boolean startConfigPortal();
boolean startConfigPortal(char const *apName, char const *apPassword = NULL);
// get the AP name of the config portal, so it can be used in the callback
String getConfigPortalSSID();
void resetSettings();
//sets timeout before webserver loop ends and exits even if there has been no setup.
//useful for devices that failed to connect at some point and got stuck in a webserver loop
//in seconds setConfigPortalTimeout is a new name for setTimeout
void setConfigPortalTimeout(unsigned long seconds);
void setTimeout(unsigned long seconds);
//sets timeout for which to attempt connecting, useful if you get a lot of failed connects
void setConnectTimeout(unsigned long seconds);
void setDebugOutput(boolean debug);
//defaults to not showing anything under 8% signal quality if called
void setMinimumSignalQuality(int quality = 8);
//sets a custom ip /gateway /subnet configuration
void setAPStaticIPConfig(IPAddress ip, IPAddress gw, IPAddress sn);
//sets config for a static IP
void setSTAStaticIPConfig(IPAddress ip, IPAddress gw, IPAddress sn);
//called when AP mode and config portal is started
void setAPCallback( void (*func)(WiFiManager*) );
//called when settings have been changed and connection was successful
void setSaveConfigCallback( void (*func)(void) );
//adds a custom parameter, returns false on failure
bool addParameter(WiFiManagerParameter *p);
//if this is set, it will exit after config, even if connection is unsuccessful.
void setBreakAfterConfig(boolean shouldBreak);
//if this is set, try WPS setup when starting (this will delay config portal for up to 2 mins)
//TODO
//if this is set, customise style
void setCustomHeadElement(const char* element);
//if this is true, remove duplicated Access Points - defaut true
void setRemoveDuplicateAPs(boolean removeDuplicates);
private:
std::unique_ptr<DNSServer> dnsServer;
std::unique_ptr<ESP8266WebServer> server;
//const int WM_DONE = 0;
//const int WM_WAIT = 10;
//const String HTTP_HEADER = "<!DOCTYPE html><html lang=\"en\"><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\"/><title>{v}</title>";
void setupConfigPortal();
void startWPS();
const char* _apName = "no-net";
const char* _apPassword = NULL;
String _ssid = "";
String _pass = "";
unsigned long _configPortalTimeout = 0;
unsigned long _connectTimeout = 0;
unsigned long _configPortalStart = 0;
IPAddress _ap_static_ip;
IPAddress _ap_static_gw;
IPAddress _ap_static_sn;
IPAddress _sta_static_ip;
IPAddress _sta_static_gw;
IPAddress _sta_static_sn;
int _paramsCount = 0;
int _minimumQuality = -1;
boolean _removeDuplicateAPs = true;
boolean _shouldBreakAfterConfig = false;
boolean _tryWPS = false;
const char* _customHeadElement = "";
//String getEEPROMString(int start, int len);
//void setEEPROMString(int start, int len, String string);
int status = WL_IDLE_STATUS;
int connectWifi(String ssid, String pass);
uint8_t waitForConnectResult();
void handleRoot();
void handleWifi(boolean scan);
void handleWifiSave();
void handleInfo();
void handleReset();
void handleNotFound();
void handle204();
boolean captivePortal();
boolean configPortalHasTimeout();
// DNS server
const byte DNS_PORT = 53;
//helpers
int getRSSIasQuality(int RSSI);
boolean isIp(String str);
String toStringIp(IPAddress ip);
boolean connect;
boolean _debug = true;
void (*_apcallback)(WiFiManager*) = NULL;
void (*_savecallback)(void) = NULL;
int _max_params;
WiFiManagerParameter** _params;
template <typename Generic>
void DEBUG_WM(Generic text);
template <class T>
auto optionalIPFromString(T *obj, const char *s) -> decltype( obj->fromString(s) ) {
return obj->fromString(s);
auto optionalIPFromString(...) -> bool {
DEBUG_WM("NO fromString METHOD ON IPAddress, you need ESP8266 core 2.1.0 or newer for Custom IP configuration to work.");
return false;
#endif
