Just read OP, he’s using WS2801 strip, which is 5050 RGB, they are rated 12V, with max draw of 20mA per colour.
Excuse me, I was thinking the ws2812b …
But still, if you measure it, you know for sure
Hello sir
Am using the WS2801 which has data clock and -+
Am powering the 24 leds from the 5v pin at the wemos d1 mini
Before I install it I checked the amps when is it not fully color it not drawing a lot of amps just 0.2
When I choice the patterns it’s just drawing 0.5 amps
And less
It’s been on 24/7 never turned off and still it’s in very good condition working .
What kind of strip u wanna use I’ll try to help u out
Hi @dananmo I am going to use ws2812b strip which I think is just the same. Do you have a copy of your code the cube is actually running and could you paste it here ???
Cheers
Kev
Sure I have copy and I’ll post it as soon as am home
thanks man that would be really useful
Cheers
Kev
hello here is the code
just coz am using WS2801 so i had to add CLOCK PIN and
here i had to add the CLOCK PIN also
FastLED.addLeds<LED_TYPE, DATA_PIN,CLOCK_PIN, LED_ARRANGE>(leds, LED_NUMBER);
in ur case u dont need it just coz u have just ± DATA PIN
so u will have just DATA PIN D2
and
FastLED.addLeds<LED_TYPE, DATA_PIN, LED_ARRANGE>(leds, LED_NUMBER);
this is the rest of the code
#include <ArduinoOTA.h>
#include <FastLED.h>
//#include <wifi_credentials.h>
//#include "settings.h"
Settings
Blynk Auth Code
#define AUTH "xxxxx"
WS28xx Config
#define LED_TYPE WS2801
#define LED_ARRANGE GRB
#define LED_NUMBER 24
#define LED_LIMIT_MILLIAMPS 2000 // Limit current in mA (Must be using FastLED v3.1.1+)
Zone - Assign a zone to your hardware
In the Blynk App, fill out the Menu Widget at the top with the different
zones you want to control.
Typically this is each room or area so you can control the entire
zone at once, and exclude other zones. Example below:
Zone 0 = reserved (will return nothing as its a false)
Zone 1 = reserved (to control "all" zones at once)
Zone 2 = Office (Menu Widget Item 1)
Zone 3 = Lounge (Menu Widget Item 2)
Zone 4 = Outside (Menu Widget Item 3)
etc.. you can go until your menu widget doesnt let you add more.
//#define ZONE 2
#define ZONE 3
Nickname - Unique name for each node
Typically this would be the zone name, followed by the node number.
In my home, I have 2 nodes in each room. So I call them OFFICE1, OFFICE2, LOUNGE1, LOUNGE2.
//#define NICKNAME "Swimming_Pool"
#define NICKNAME "Magic Cube"
Over The Air Hostname
I try to use the NICKNAME (above) as the name to identify it in the IDE.
Althought you can use what ever you like.
//#define OTA_HOSTNAME "LED-Swimming_Pool"
#define OTA_HOSTNAME "Magic Cube"
Local Server Settings (uncomment to use local server)
//#define USE_LOCAL_SERVER
//#define SERVER IPAddress(192, 168, 1, 2)
#define BLYNK_MSG_LIMIT 400
Hardware Pins
#define DATA_PIN D2// GPIO12 / D6 on WeMos/NodeMCU ESP8266
//#define CLOCK_PIN D8
Virtual Pins
#define vPIN_HUE V0
#define vPIN_SATURATION V1
#define vPIN_BRIGHTNESS V2
#define vPIN_PRESET V3
#define vPIN_FPS V5
#define vPIN_COLOUR_BLUE V4
#define vPIN_COLOUR_RED V6
#define vPIN_COLOUR_GREEN V7
#define vPIN_COLOUR_WHITE V8
#define vPIN_TERMINAL V9
#define vPIN_MANUAL V10
#define vPIN_SYNC_GHUE V11
#define vPIN_TEST V12
#define vPIN_ALERT V13
#define vPIN_OFF V14
#define vPIN_RAINBOWSPEED V22
#define vPIN_ZONE_SELECT V23
#define vPIN_TESTMODE V24
#define vPIN_COLOUR_MEM1 V25
#define vPIN_COLOUR_MEM2 V26
#define vPIN_COLOUR_MEM3 V27
#define vPIN_COLOUR_MEMSAVE V28
#define vPIN_NIGHTMODE V29
int varSpeed, varRainbowSpeed, varAlertMode, varZone;
int testLEDnumber, varMemSave;
int arrayCurrent[5], arrayMemory1[5], arrayMemory2[5], arrayMemory3[5], arrayNightMemory[5];
WidgetTerminal terminal(vPIN_TERMINAL);
CRGB leds[LED_NUMBER];
WiFi.mode(WIFI_STA);
Blynk.begin(AUTH, "USERNAME", "PASSWORAD");
//#endif
while (Blynk.connect() == false) {}
/*********** OTA *************/
ArduinoOTA.setHostname(OTA_HOSTNAME);
ArduinoOTA.begin();
/******** BOOT VARS **********/
arrayCurrent[0, 255, 255, 255]; // Set starting sequence as rainbow mode
varSpeed = 100; // Start on 100 fps
varZone = 1;
varRainbowSpeed = 0; // Start stationary
/******** FASTLED ************/
#ifdef LED_LIMIT_MILLIAMPS
FastLED.setMaxPowerInVoltsAndMilliamps(5, LED_LIMIT_MILLIAMPS);
#endif
/******** READY **************/
terminal.print(F("# Blynk v" BLYNK_VERSION ": "));
terminal.print(NICKNAME);
terminal.println(F(" Device started"));
terminal.flush();
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle};
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
String CurrentHexRGB() {
return String("#") + String(((long)leds[0].r << 16) | ((long)leds[0].g << 8 ) | (long)leds[0].b, HEX);
BLYNK_WRITE(vPIN_HUE) {
if (varZone == ZONE || varZone == 1) {
updateColours(arrayCurrent[0], param.asInt(), arrayCurrent[2], arrayCurrent[3]);
//Blynk.setProperty(vPIN_HUE, "color", CurrentHexRGB());
BLYNK_WRITE(vPIN_SATURATION) {
updateColours(arrayCurrent[0], arrayCurrent[1], param.asInt(), arrayCurrent[3]);
BLYNK_WRITE(vPIN_BRIGHTNESS) {
updateColours(arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], param.asInt());
BLYNK_WRITE(vPIN_FPS) {
if (varZone == ZONE || varZone == 1) varSpeed = param.asInt();
BLYNK_WRITE(vPIN_PRESET) {
if (varZone == ZONE || varZone == 1 && param.asInt()) nextPattern();
BLYNK_WRITE(vPIN_COLOUR_RED) {
if (varZone == ZONE || varZone == 1 && param.asInt()) {
updateColours(1, 96, 255, 255);
updateWidgets();
BLYNK_WRITE(vPIN_TEST) {
if (varZone == ZONE || varZone == 1 && param.asInt()) gCurrentPatternNumber+1;
BLYNK_WRITE(vPIN_COLOUR_GREEN) {
updateColours(1, 0, 255, 255);
updateWidgets();
BLYNK_WRITE(vPIN_COLOUR_BLUE) {
updateColours(1, 159, 255, 255);
updateWidgets();
BLYNK_WRITE(vPIN_COLOUR_WHITE) {
updateColours(1, 255, 0, 255);
updateWidgets();
BLYNK_WRITE(vPIN_MANUAL) {
updateColours(param.asInt(), arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]);
updateWidgets();
BLYNK_WRITE(vPIN_SYNC_GHUE) {
gHue = 0;
varSpeed = 100;
terminal.println(" | Sync'd gHUE ");
terminal.flush();
BLYNK_WRITE(vPIN_ALERT) {
varAlertMode = param.asInt();
BLYNK_WRITE(vPIN_OFF) {
if ( varZone == ZONE || varZone == 1 && param.asInt()) {
updateColours(1, 255, 255, 0);
updateWidgets();
BLYNK_WRITE(vPIN_RAINBOWSPEED) {
if ( varZone == ZONE || varZone == 1) {
varRainbowSpeed = param.asInt();
Blynk.virtualWrite(vPIN_RAINBOWSPEED, varRainbowSpeed);
BLYNK_WRITE(vPIN_ZONE_SELECT) {
varZone = param.asInt();
if (varZone == ZONE) {
terminal.println(" | Zone Selected!");
terminal.flush();
updateColours(arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]);
Blynk.virtualWrite(vPIN_FPS, varSpeed);
BLYNK_WRITE(vPIN_COLOUR_MEM1) {
if (varMemSave) {
arrayMemory1[arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]];
Blynk.setProperty(vPIN_COLOUR_MEM1, "color", CurrentHexRGB());
updateColours(arrayMemory1[0], arrayMemory1[1], arrayMemory1[2], arrayMemory1[3]);
updateWidgets();
BLYNK_WRITE(vPIN_COLOUR_MEM2) {
if (varMemSave) {
arrayMemory2[arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]];
Blynk.setProperty(vPIN_COLOUR_MEM2, "color", CurrentHexRGB());
updateColours(arrayMemory2[0], arrayMemory2[1], arrayMemory2[2], arrayMemory2[3]);
updateWidgets();
BLYNK_WRITE(vPIN_COLOUR_MEM3) {
if (varMemSave) {
arrayMemory3[arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]];
Blynk.setProperty(vPIN_COLOUR_MEM3, "color", CurrentHexRGB());
updateColours(arrayMemory3[0], arrayMemory3[1], arrayMemory3[2], arrayMemory3[3]);
updateWidgets();
BLYNK_WRITE(vPIN_COLOUR_MEMSAVE) {
varMemSave = param.asInt();
BLYNK_WRITE(vPIN_TESTMODE) {
if (param.asInt()) {
updateColours(2, arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]);
testLEDnumber = param.asInt();
updateColours(0, arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]);
BLYNK_WRITE(vPIN_NIGHTMODE) {
arrayNightMemory[arrayCurrent[0], arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]];
updateColours(1, 152, 255, 100);
updateWidgets();
updateColours(arrayNightMemory[0], arrayNightMemory[1], arrayNightMemory[2], arrayNightMemory[3]);
updateWidgets();
void updateColours(int m, int h, int s, int b) {
arrayCurrent[0] = m;
arrayCurrent[1] = h;
arrayCurrent[2] = s;
arrayCurrent[3] = b;
void updateWidgets() {
Blynk.virtualWrite(vPIN_MANUAL, arrayCurrent[0]);
Blynk.virtualWrite(vPIN_HUE, arrayCurrent[1]);
Blynk.virtualWrite(vPIN_SATURATION, arrayCurrent[2]);
Blynk.virtualWrite(vPIN_BRIGHTNESS, arrayCurrent[3]);
void loop(){
ArduinoOTA.handle();
switch (varAlertMode) {
case 1:
for (int i = 0; i < 20; i++) {
fill_solid(leds, LED_NUMBER, CRGB::White);
FastLED.show();
delay(50);
fill_solid(leds, LED_NUMBER, CRGB::Black);
FastLED.show();
delay(50);
varAlertMode = 0;
break;
case 2:
for (int i = 0; i < 5; i++) {
FastLED.show();
delay(250);
FastLED.show();
delay(50);
FastLED.show();
delay(50);
FastLED.show();
delay(250);
varAlertMode = 0;
break;
case 3:
for (int i = 0; i < 10; i++) {
fill_solid(leds, LED_NUMBER, CRGB::Blue);
FastLED.show();
FastLED.delay(50);
fill_solid(leds, LED_NUMBER, CRGB::Red);
FastLED.show();
FastLED.delay(50);
varAlertMode = 0;
break;
case 4:
FastLED.show();
FastLED.delay(50);
FastLED.show();
FastLED.delay(50);
varAlertMode = 0;
break;
switch (arrayCurrent[0]) {
case 1:
fill_solid(leds, LED_NUMBER, CHSV(arrayCurrent[1], arrayCurrent[2], arrayCurrent[3]));
break;
case 2:
FastLED.clear();
for (int led = 0; led < testLEDnumber; led++) leds[led] = CRGB::Blue;
break;
default:
gPatterns[gCurrentPatternNumber]();
EVERY_N_MILLISECONDS( 20 ) gHue++; // slowly cycle the "base color" through the rainbow
break;
FastLED.show();
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern() {
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE(gPatterns);
void rainbow() {
// FastLED's built-in rainbow generator
fill_rainbow( leds, LED_NUMBER, gHue, varRainbowSpeed);
FastLED.delay(1000 / varSpeed);
void rainbowWithGlitter() {
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter) {
if ( random8() < chanceOfGlitter) leds[ random16(LED_NUMBER) ] += CRGB::White;
void confetti() {
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, LED_NUMBER, 20);
int pos = random16(LED_NUMBER);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon() {
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, LED_NUMBER, 10);
int pos = beatsin16(13, 0, LED_NUMBER);
leds[pos] += CHSV( gHue, 255, 192);
void juggle() {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for ( int i = 0; i < 8; i++) {
leds[beatsin16(i + 7, 0, LED_NUMBER)] |= CHSV(dothue, 200, 255);
dothue += 32;
am also like u sir i try to do my best to make it work
if u have any improvments ill be very happy to see it ,
also looking forward to see ur project
thank u
also all the V PINS i had to add it in the code coz i wasnt able to add the file in the library
if u need any help ill be happy to help u
Cheers @dananmo I will let you know how I get on with it
How did you stick the whole cube together - did you just glue the plexiglas to the wood ?
Also what diameter hole is in the middle and what size is the cube itself ?
Cheers
Kev
The size of the cube I had wood laying around its 8x8 .,
And either u can use the wood glue or epoxy
I used wood glue and let it set for one day .
But before u stick the plexi make sure u sand it both faces so the light will reflect more inside .
The hole is 3" I had holesaw after u glue all of it in the end sand it and make all the surface equals then u can stain it or laker it .
The last layer which is the base don’t glue it i case u want to trouble shoot it in future .
