@Dolly please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I apologize, but my knowledge is not very rich in programming. I can’t handle it, can you give me another example?
I tried this, but nothing happens. #define BLYNK_PRINT Serial
#include <Ticker.h> // Install from Arduino Library Manager
#define blue_led 2 // NodeMCU onboard LED attached to GPIO2 (D4)
Ticker blueticker; // Initialise the Ticker object called blueticker
char auth[] = "_2DX-EyR20G_KRKk9vD";
char ssid[] = "1";
char pass[] = "t20";
pinMode(blue_led, OUTPUT);
void flashblue() // Non-blocking ticker for Blue LED
int state = digitalRead(blue_led); // get the current state of the blue_led pin
digitalWrite(blue_led, !state); // set pin to the opposite state
blueticker.attach(0.5, flashblue);
Looks like you’re probably back to using lambda timers or a combination of a timer and a ticker, but I don’t have the time or the inclination to explain the detail of how you might implement that.
