I’m creating a PID sous vide controller, and i found it to easy to turn it on and of with just a button widget. So i created this Long press button. I thought others might find it usefull.
It doesn’t seem to slow down or affect code(but i haven’t done heavy testing, and im no expert
int longPressMillis = 1000; // time in millis needed for longpress
boolean buttonState = false
// Blynk On/Off button in app
BLYNK_WRITE(1) {
if (param.asInt() == 1) { // if button is pressed
longPressTimer = timer.setTimeout(longPressMillis, onOffToggle); // start the timer to run the function in defined time
timer.deleteTimer(longPressTimer); // Stop and delete the timer if button is released to early
// Function called by BLYNK_WRITE(1)
// This function toggles something
void onOffToggle() {
if (buttonState == true) {
// do something if true
buttonState = false;
// do something if not true
buttonState = true;
