Eu usava o App Antigo do Blynk para este projeto, no Novo Blynk não roda.
@Lincon Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Copy and paste these if you can’t find the correct symbol on your keyboard, do not use Blockquotes as you are at the moment.
Void loop must be clean , search through the forum.
a programação que esta loop vai pra onde ?
@Lincon I’ve removed the code from your first post in this topic, as you didn’t follow the guidelines for how to post code correctly, and ignored my request for you to fix the issue.
I’d suggest that you read this…
especially the part that says…
So if you use
Blynk.virtualWrite(V1, sensorValue)in the loop, you send gazillion messages to Blynk Cloud from your hardware. When it happens, Blynk automatically disconnects your device for spamming. Sorry.
