Greetings. I am very new with any blynk and electronics in general and I’m having trouble getting my project connected. I have an arduino UNO with an adafruit motor shield on top, then an HC-06 connected to that.
I uploaded this code to connect the bluetooth:
char auth[] = "XXXX";
SoftwareSerial SerialBLE(10, 11); // RX, TX
SerialBLE.begin(9600);
Blynk.begin(SerialBLE, auth);
// to avoid delay() function!
However, it won’t connect. Most of the time, on the blynk app, it says “not online yet.” Even when it says “online” and led on the hc-06 is steady, the serial monitor says “login timeout.”
I usually upload the code with USB onto the arduino, then connect the shield and the hc-06. I tried it without the shield and the same thing happened. Since the device is saying that “Wasn’t online yet”, I am guessing that this is also a connection to cloud problem. Seems like it is not connecting to the Blynk-cloud. Thank you!
So… which one are you intending you use on those pins? They can’t share
Since it appears you are using the SerialBLE, then delete the other just in case it is adding to the issue.
Then make sure your TX/RX connections are properly wired (RX from one dev goes to TX on the other)
Confirm that the BLE module is properly powered and that the BAUD rast programmed into it is the same as the 9600 you are using on the sketch.
And finally, double check your AUTH
The module LED status only refers to the pairing between itself and the phone.
However, If the App says “online”, then it should in fact be online… and thus have printed the “Waiting for connections…” message since Blynk.begin() is a blocking command and should not allow further processing until actual server link (via phone) is established.
Perhaps you missed that message or are mistaken about the “online” part??
I see… Please report any Sketch Builder issues via the reporting button in the lower right corner of that page. Then the developers may correct them. Thanks.
