http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you’ll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "0HYGVE5MuxEHATWVKaPJLtj7FcblRdGQ";
#define DHTPIN 2
#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h))
Blynk.virtualWrite(V5, h);
// Blynk will work through Serial1
Serial1.begin(9600);
Blynk.begin(Serial, auth);
dht.begin();
timer.setInterval(10000, sendSensor);
