Login timeout:80
somebody can help me
i try make project but i fail login blynk-cloud.com:80
thank
When you talked a question on to the end of a year old topic, which may or may not have been relegated to your issue, I asked you to:
When you created this topic you were presented with a template that prompted you to provide retails of the type of hardware that you are using, the versions of the libraries being used, the code you are using, etc. etc.
If you choose not to provide that type of information then don’t be surprised when community members don’t rush to your assistance.
i use nodemcu esp8266 and modem for connect internet at home
and then this ny code
The text that you deleted when you created this project also explained how to post text correctly, using triple backticks, but clearly you listed that detail too.
Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code.
done edit my code sir ?
No. I’ve given you some triple backticks to copy and paste, but you’ve chosen to use different characters instead - which don’t work.
Please edit your code again and use the correct characters.
I have same trouble, and solved by changing port from 80 to 8080
It may be ISP port blocking…
