Locked widget
Hello @neurona.
We investigated your case.
1. You subscribed in web console to PLUS plan annually on 16.01.2022. According to our data, your subscription renewal is 16.01.2024.
Also, according to our data, you did not cancel or change your subscription. Can you confirm this?
Сan you explain what you meant?
2.
This related only to users wich registered and subscribed after 16.10.2023 Upcoming Plan Updates!
If you haven’t changed anything in your subscription, these widgets should still be available for you.
3. According to your screenshot, it looks like you are using iOS.
  1. What is you phone model?
  2. What OS version?
  3. What Blynk IoT app version you use?
4. Perhaps you still have a cache in the application.
Please delete Blynk app. Install last app version. Login to app, and check your devices for availability of these widgets
If reinstalling the application did not help, please send us the logs.
Path logs:
Main left menu → About → Send logs
Also write us a comment in this forum post. Did reinstalling the application help you or did you send the logs.
Regards
