Hi everyone,
My blynk project has RTC widget but i cant get correct time (espicially hour)… My local server runs in Rasp pi3 and its localisitaon setting correct (GMT+3, Europe, İstanbul). My RP3 time is correct.
I chose same GMT+3 in RTC widget but my code always give me wrong hour data. It is always minus 1. Correct time (for example) 17:00 my blynk widget give to me 16:00 …
When I rise up GMT+4 then its plus 2…when correct time (for example) 17:00, it gives me 19:00
We couldnt meet in the middle point…unfortunatelly…
here is the code;
#include <TimeLib.h>
#include <WidgetRTC.h>
#define blue "#04C0F8"
#define red "#D3435C"
#define white "#FFFFFF"
String CorrectedTime;
float RoomTemp;
float Humidity;
boolean RelayPosition;
int set;
int WakeUpTime;
int EcoTime;
int ComingHome;
int WeekendWakeUpTime;
const int Relay = 5;
char auth[] = "f6d57acf8f7a44d29e74a93189d950d1";
char ssid[] = "SUPERONLINE_WiFi_0161";
char pass[] = "xxxxxxx";
WidgetRTC rtc;
#include <nRF24L01p.h>
void Updates()
Blynk.virtualWrite(V4, Relay);
Blynk.virtualWrite(V2, set);
void TimeFunction()
int HourNumber = hour();
if (HourNumber == 24) {
HourNumber = 0;
String ShowHour = String(HourNumber, DEC);
int HourLenght = ShowHour.length();
if (HourLenght == 1) {
ShowHour = "0" + ShowHour;
String ShowMinute = String(minute(), DEC);
int MinuteLength = ShowMinute.length();
if (MinuteLength == 1) {
ShowMinute = "0" + ShowMinute;
String ShowSecond = String(second(), DEC);
int SecondLength = ShowSecond.length();
if (SecondLength == 1) {
ShowSecond = "0" + ShowSecond;
String ShowDay = String(day(), DEC);
int DayLength = ShowDay.length();
if (DayLength == 1) {
ShowDay = "0" + ShowDay;
String ShowMonth = String(month(), DEC);
int MonthLength = ShowMonth.length();
if (MonthLength == 1) {
ShowMonth = "0" + ShowMonth;
String Weekday;
int DayCorrection = -1;
if (weekday() == 1)
DayCorrection = 6; // For Sunday. Time library is day 1 and Blynk is day 7
if ((weekday() + DayCorrection) == 1)
Weekday = "MONDAY";
else if ((weekday() + DayCorrection) == 2)
Weekday = "TUESDAY";
else if ((weekday() + DayCorrection) == 3)
Weekday = "WEDNESDAY";
else if ((weekday() + DayCorrection) == 4)
Weekday = "THURSDAY";
else if ((weekday() + DayCorrection) == 5)
Weekday = "FRIDAY";
else if ((weekday() + DayCorrection) == 6)
Weekday = "SATURDAY";
Weekday = "SUNDAY";
CorrectedTime = ShowHour + ":" + ShowMinute + ":" + ShowSecond + " " + ShowDay + "." + ShowMonth + "." + year() + " " + Weekday;
Blynk.virtualWrite(V21, CorrectedTime);
Blynk.virtualWrite(V24, hour());
nRF24L01p receiver(D8, D4); // CSN = D8, CE = D4
boolean ManuelMode; // Start with "auto" mode
int eco = 19; // eco time from 08:00 to 18:00
int normal = 23; // normal time from 18:00 to 24:00
int night = 19; // night time from 24:00 to 06:00
void RF()
while (receiver.available()) // if any temp data comes
receiver.read(); // receive them
receiver.rxPL(RoomTemp);
receiver.rxPL(Humidity);
Blynk.virtualWrite(V1, RoomTemp); // then send them to app
Blynk.virtualWrite(V0, Humidity);
if (set > RoomTemp) // if room temp lower than set value..
digitalWrite(Relay, HIGH); // turn on the heater
RelayPosition = 1023;
Blynk.setProperty(V4, "label", "ON");
digitalWrite(Relay, LOW);
RelayPosition = 0;
Blynk.setProperty(V4, "label", "OFF");
void WeeklySchedule() // Weekly program
RF(); // first listen to transmitter (nRF)
if (!ManuelMode) // if manuel mode off
int DayCorrection = -1; // correct the day
if (weekday() == 1)
DayCorrection = 6; // For SUNDAY, Time library is day 1 and Blynk is day 7
if ((weekday() + DayCorrection) <= 5) // if it is workday
if (hour() < WakeUpTime) // when the time between 24:00 - 06:00
set = night; // set the temp to night
Blynk.virtualWrite(V3, "Night");
else if (hour() < EcoTime) // when the time between 06:00 - 08:00
set = normal; // set the temp to normal
Blynk.virtualWrite(V3, "Normal");
else if (hour() < ComingHome - 1) // when the time between 08:00 - 18:00
set = eco; // set the temp to eco
Blynk.virtualWrite(V3, "Eco");
else // when the time between 18:00 - 24:00
set = normal;
else if ((weekday() + DayCorrection) > 5) // if weekend
if (hour() <= WeekendWakeUpTime - 1) // when the time between 24:00 - 07:00
Blynk.virtualWrite(V3, "Weekend Night");
else // when the time between 07:00 - 24:00
Blynk.virtualWrite(V3, "Weekend Normal");
else // if manuel mode on...
RF(); // run for the manuel set temp
BLYNK_WRITE(V10)
int pindegeri = param.asInt();
if (pindegeri > 18) // if set temp higher then 18 celcius by the silder manually
set = pindegeri;
ManuelMode = true; // Manuel Mode will be on
Blynk.setProperty(V5, "color", red);
Blynk.virtualWrite(V5, "MANUEL");
Blynk.setProperty(V10, "label", "MANUEL");
else // if set temp equal the 18 celcius heater runs in auto mode with pre def set temp values in void_setup
ManuelMode = false;
Blynk.setProperty(V5, "color", blue);
Blynk.virtualWrite(V5, "AUTO");
Blynk.setProperty(V10, "label", "AUTO");
BLYNK_WRITE(V11)
int pinValue = param.asInt();
if (param.asInt() < EcoTime)
WakeUpTime = pinValue;
Blynk.virtualWrite(V15, WakeUpTime);
Blynk.virtualWrite(V9, String("night ends on: ") + WakeUpTime);
WakeUpTime = EcoTime - 2;
BLYNK_WRITE(V12)
if (param.asInt() < ComingHome)
EcoTime = pinValue;
Blynk.virtualWrite(V16, EcoTime);
Blynk.virtualWrite(V9, String("Eco time starts on: ") + EcoTime);
EcoTime = WakeUpTime + 2;
BLYNK_WRITE(V13)
ComingHome = param.asInt();
Blynk.virtualWrite(V17, ComingHome);
Blynk.virtualWrite(V9, String("Coming Home on: ") + ComingHome);
BLYNK_WRITE(V14)
WeekendWakeUpTime = param.asInt();
Blynk.virtualWrite(V18, WeekendWakeUpTime);
Blynk.virtualWrite(V9, String("weekend night ends: ") + WeekendWakeUpTime);
Blynk.virtualWrite(V3, "Starting...");
WakeUpTime = 6;
EcoTime = 8;
ComingHome = 18;
WeekendWakeUpTime = 8;
Blynk.virtualWrite(V5, "Auto");
Blynk.setProperty(V10, "label", "Auto");
pinMode (Relay, OUTPUT);
digitalWrite (Relay, LOW);
RelayPosition = false;
ManuelMode = false;
Blynk.begin(auth, ssid, pass, IPAddress(192, 168, 1, 50));
rtc.begin();
SPI.begin();
timer.setInterval(2000L, Updates);
SPI.setBitOrder(MSBFIRST);
receiver.channel(90);
receiver.RXaddress("Tamer");
receiver.init();
timer.setInterval(3000L, WeeklySchedule);
timer.setInterval(5000L, TimeFunction);
BLYNK_WRITE(V6) //Normal value change option
if (param.asInt() > 18)
normal = pinValue;
Blynk.setProperty(V19, "color", red);
Blynk.virtualWrite(V19, String("Normal RoomTemp: ") + normal);
normal = 23;
BLYNK_WRITE(V7) //eco value change option
eco = pinValue;
Blynk.setProperty(V19, "color", blue);
Blynk.virtualWrite(V19, String("Eco RoomTemp: ") + eco);
eco = 19;
BLYNK_WRITE(V8)
eco = pinValue;
Blynk.setProperty(V19, "color", white);
Blynk.virtualWrite(V19, String("Night RoomTemp: ") + night);
eco = 19;
Here is my info s…
1. The Blynk library version you are using. **(0.4.6)** 2. Android or iOS and the version of the OS. **(Android 5.0)** 3. Server type, Local or Cloud based. **(Local Server)** 4. If local server, which version you are using. **0.28.3** 5. How you powering the MCU. **(with USB)** 6. Has the MCU ever connected to a Blynk server (Cloud or local). **(yes)** 7. The IDE you areusing, including the version number. **(Arduino 1.8.0)** 8. The settings you have in the IDE for the MCU. **(NodeMCU 1.0 (ESP-12E Module)** 9.The Arduino core version you are using. **(1.8.0)** 10. The make and model of your phone. **(Samsung Note 3)**
here is the QR
what must i do?
