I lost my password for the admin pages. Is there a way to reset fro pi console or password recovery?
You can try restarting the server, apparently the default login gets re-enabled when that happens, I think if you haven’t changed that password then you can login that way.
You need to remove admin@blynk.cc file from your data folder and restart server.
Thank you…You are very quick to respond and greatly appreciate your attentiveness.
I have the same problem, updated from 0.22.2 to 0.24.5 and now admin page moved to port 9443 and I have to enter password (I didn’t remember it). Tried remove admin@blynk.cc but it can’t help. Also can someone explain what does it mean in config reset-pass.http.host= and how I can change password via UI?
Hello. All you need is
- Stop server;
- Remove file admin@blynk.cc in your data folder;
- Start server;
- Login with provided credentials;
This property is no longer used.
Thanks, it works.
p.s. - 4) Login with provided credentials (login: admin@blynk.cc password: admin)
yikes. I[quote=“Dmitriy, post:3, topic:13588, full:true”]
[/quote]
Has this been disabled ?
I forgot my main account login due to not having had the need to use its password for a long time. After removing admin@blynk.cc from data folder and restarting the server I dont get a new admin account either (I had changed its password aswell and can’t remember it lols)
Yes I did but im fine now ^.^ i remembered my password thankfully I could give a good 20 atempts without getting blocked or so
