I’m wondering, if anyone using local server has the same issue: Today, while testing the debugging server versions I’ve noted, that Blynk log files are directed to
{current_dir}/${sys:logs.folder}
The server after startup prints it’s usual:
Blynk Server 0.38.3-SNAPSHOT successfully started.
All server output is stored in folder '/home/blynk/data/logs' file.
And YES, files are created there, but they are empty…
Instead, all logs are redirected to the above:
WTF!?? Again the same on the SAME server as yours…! The folder for logs IS created, but all logs are found in this $%^*&$ “thing”… WHO BROKE MY SERVER!!?
Yeah… sure it helps… It just means my “setup” got f…
@Gunner, what is your java version (java -version )
I am actually deleting all old folders and logs to be sure that I am not looking at ghosts… as can happen if I don’t remember to refresh my WinSCP screen
I recall having the same issue, a while back a dev asked me for the log info and it turned out to be empty, after digging around I found it in the same spot you have it. I’ll check what my current log status is…
Yup, not much, but every penny counts
Your logs are in correct folder which itself seems to be in incorrect (?) location. Mine tries to be a clever guy, who doesn’t want to listen to mine orders. It creates folder structure, but writes to its own, choosen location. Ok, I’m stupid, “he’s” right.
