Hi All.
I’ve recently updated my RP3, which is running the local Blynk server and have not been able to connect to is with my ESP8266 since. The error I get looks like this:
13:41:57.911 DEBUG- Unsecured connection attempt or not supported protocol. Channel : /10.0.0.178:49153. Reason : io.netty.handler.ssl.NotSslRecordException: not an SSL/TLS record: 02000100203536383033373266393562623433326561343665313135316139633336303061
My code has not changed but I am using a newer version of Blynk. I’ve attempted running the simplest bare-bones Blynk code I could on the ESP8266 but still get the same result:
char auth[] = “5680372f9…151a9c3600a”;
// Set password to “” for open networks.
char ssid[] = “SSID”;
char pass[] = “PASS”;
Blynk.begin(auth, ssid, pass, IPAddress(10,0,0,21), 8442);
// to avoid delay() function!
I’ve been at it for quite awhile now and am hoping that someone here might have an idea of what I could try.
One other thing that I updated was node.js, here is what I’m running now:
pi@raspberrypi:~ $ node -v
v10.11.0
pi@raspberrypi:~ $ npm -v
6.4.1
Thanks,
-Konstantin
