[Local Blynk Server] Safe port forward
Is there a way to stop creating new accounts?
I want to make my Raspberry Pi accessible from outside my house, and not need to connect everytime to my vpn before opening the Blynk app.
But when I use a port forward to access my Blynk server, anyone who has my ip-adress can create a new account, which I don’t want.
I tried putting this command inside op the server.properties file but this did not work so far.
allowed.users.list=allowed1@gmail.com,allowed2@gmail.com
Anyone experience with this?
EDIT1:
Sorry my bad. It did work. But now when I try to make a new account it says: “Network error occured. Please check your connection.”
But when I log in with my own allowed account, I logs in just fine. :smiley:
EDIT2:
Do I need to make my own certificate, to ensure safety? The only ports that are forwarded are 8441, 8442, 8443…
Is that iOS?
Yes. 8441 and 8443 are ssl ports. 8441 - hardware ssl/tls, 8443 app ssl/tls port.
Yes. I when I login with the allowed account I can login just fine. But the other account I want to make, it says [quote=“hutje, post:1, topic:9180”]
[/quote]
Which is just fine, but it was not clear for me.
http://www.selfsignedcertificate.com/
Can I make the certificate on this site?
Sorry I don’t know the basics of ssl and certificates, only that these files can make ports safe…
Well, If you worry about security you have to know :wink:
Not sure, but got an error…
This is what I used: ./certbot-auto certonly --agree-tos --email rxxxxxxxx@hotmail.nl --standalone -d hotmail.nl
Error: urn:acme:error:rejectedIdentifier :: Policy forbids issuing for name
I now have used the example from the docs.blynk.cc page.
Create key
openssl genrsa -out server.key 2048
Create new cert request
openssl req -new -out server.csr -key server.key
Generate self-signed request
openssl x509 -req -days 1825 -in server.csr -signkey server.key -out server.crt
Convert server.key to PKCS#8 private key file in PEM format
openssl pkcs8 -topk8 -inform PEM -outform PEM -in server.key -out server.pem
 server.ssl.cert=./server_embedded.crt
 server.ssl.key=./server_embedded.pem
 server.ssl.key.pass=xxxxxx
Is there anything else I need to do now?
No, that should be it. I use self-signed too. So far no chinese hackers have switched on my lights :wink:
